Brake Light Install Wiring Help
jeffcampagna
Hey folks,
I'm new here. Only a few scattered posts to my name. But I'm in need of the community's assistance.
I'm modifying a 2008 Suzuki GN125. I purchased a Round Tail Brake Light http://townmoto.com/accessories/lighting/round-taillightwithbracket from TownMoto. It has three wires: Brown, Black, Red.
My stock wiring harness also has three wires going to the tail brake light but the colors have thrown me off completely: Green, Green/Yellow, Brown.
Which ones go to which? Best guesses? Assuming there's one phase for running light and a second for braking? Anything I should know? Does one of the light wires ground to the frame? If so, what do I do with the third wire in the harness?
Any and all help would be greatly appreciated.
Try all the combos. You're not likely to hurt anything.
Those wires don't seem to be the correct color for that bike, though. Usually it's brown, black/white, and white.
Hey Sonreir,
Thanks for jumping in. I was really worried to just start trying different combos at random. Thought I might short or spark something. I'm new to electrical... can you tell? But perhaps that's what I'll try.
Strange that the wires would be different from stock. Well, not entirely strange. I am based in Panama, Central America and you never really know if previous owners mucked anything up—they certainly don't tell you when you buy a bike...
It's OK. 9 times out of 10 it'll just not work properly until you find the right combination. Maybe blow a fuse if you're unlucky, but that's about it.
Hey Sonreir and Co,
So, I spent all morning playing with wires...
No matter which combination I tried (and I tried them ALL), I kept getting the exact same result: light turns on when brakes are applied but there are no running lights whatsoever, when the brakes are not applied, the light is simply off.
Why do all the combinations work to achieve the same result? (I thought electrical was a bit more specific than that.)
Is it possible the brake light I bought doesn't support running lights?
As always, any and all help or suggestions are greatly appreciated. ugh... electrical...
That is possible, but the opposite is more likely. It's a tail light and not a brake light.
That said, three wires almost always means it's a tail and a brake in one.
Have you pulled the cover and checked if the bulb is OK?
Just pulled the cover off. Filaments look fine. No burns. No rattling. And there are two separate filaments so the light is certainly built to supply both running and brake lights...
Should I be grounding one of the three light wires to the frame? Will it change the result?
Could it be a fuse? Or would the light not work at all if there was a blown fuse?
Thanks again for the help.
Grab your multimeter and read resistance between the metal bulb housing and each of the wires. This should at least find which wire is the ground. My money is on the black wire.
Agreed. I think the black wire from the light is ground as well. And from the harness, my money is on the Green/Yellow being ground as usual.
But I still can't get a winning combo from the remaining Brown, Red to Brown, Green.
Guess I'll have to drive up to the ferreteria (hardware store) and look for multimeters.
PS. I thought the Green/Yellow in the harness would be ground, cause it's common in other applications. But according to your major manufacturer wiring colors list in the forum, Honda uses Green/Yellow specifically for Brake Lights...
Yes. But maybe Japanese manufactures have similar wiring standards. Who knows. I'm grasping at straws.
Just can't wrap my mind around what the issue would be if I've tried every single possible wire combination with no success.
I see one of two options.
Either the wires coming from the bike don't have power when they should, or the light doesn't work as it should.
For what it's worth, the three wires on the bike are exactly Honda colors, though. Green - Ground, Green/yellow - Brake, and Brown - Tail Light.
Grab a 12v test light and connect it from Green to green/yellow and apply the brakes. Does the test lamp light up?
Then connect it to green on one side of the test lamp and Brown on the other side and see if lights up when you turn the lights on. If not, find out why. This should not be difficult.
Trust the force, young jeffcampagna you must
