Brake light switch for front drum?
woody1981
Coast to Coast
DTT BOTM WINNER
I am in the process of switching my CB450 over to a drum front brake instead of the stock disk front (K5). My question is how do you people hook up a front brake light switch to the normal CB450 setup. I am using Amal style after market levers if that makes any difference. Thanks.
- Woody
I'm in the same pickle with my XS650, as I am also using aftermarket Tommaselli Matador levers.
One option is a lever with the brake light switch integrated. Some stock levers have this, or you can adapt a clutch safety switch to do the trick also.
The option I'm going to try and use is many front drum brake cables, especially it would seem British ones, have a brake light switch integrated in the cable itself. There is a set of leads coming from the cable housing that you tie into your wiring and they activate the brake light.
So I got a stock XS650 drum brake cable to compare to some cables with the switch integrated to get the same inner cable/housing lengths or at least as close as possible. I haven't really dug into it yet, but that's my plan.
Tintin,
Do you have any pics of the Tommaselli levers you can post... I just got the amal knock-offs but I just saw some tommaselli style ones and I really really like the look... I am temped to switch. Can I see a pic of yours to see if its worth spending the extra $$ on the genuine ones.
Also, let me know what you find on the brake cable with integrated switch.
Thanks
-Woody
There's some Japanese bikes that have these too. It's basically two cables with a switch in the middle. The switch is situated right around the headlight area, so the wires will just go into the wiring harness. I had one of these on an old Kawi enduro that I turned into a mini chopper a few years ago. Worked really well. I'm sure there is something else out there that has this too. I'll see if I can find pics tonight and post up. What did the front drums come with for a brake switch from the factory?
I should have specified my Matador's are not originals - maybe one day I'll stumble across a set, but I may end up going with sleeker Amal style in the end. We'll see how they look when I finally get everything bolted together.
I'd say about 6 months ago, you could get aftermarket CB cables with switches in them, but I haven't seen one in a while. I have one, not that it helps you any. And unfortunately I can't seem to figure out who I purchased it from. :-[
Steve
On the bikes i've used front drum brakes, the switch is usually in the levers. the switch usally just scres in just behind the cables in the lever perch.
I'm pretty sure all front brake drum levers have this hole in them, unless they were designed for lightweight racing or you're using two clutch perches.
I'll have to look when I get home to see if I have the accommodation for the switch in my lever perch. If I do have it where do I get the switch?
- Woody
Use a cable like this that has the switch intergrated into it:
You can find them on eBay etc. The trick is to find one the right length etc. as what you need. That's what I'll end up using on my bike, but the final selection will come when I have a chance to measure things up and determine which make/model of cable I need.
I'm also looking for a black one, which may make the search more difficult.
Yeah. I found a NOS norton one on there I'm thinking about trying. I am also looking for black... damn we're picky sons-of-bitchs. I think I can have the end re-swaged so if thats the case I will just shorten the housing and cable as needed and then have it that done... or there are clamp on swags that are brass and use a setscrew or two. Might be an option too... would just have to keep an eye on it.
Whatever I do, I at least feel better knowing I will have brake lights when I apply the front brake.
- Woody
hey guys, for what it is worth I figured I would say my 73 tx 650 is getting overhauled with the drum from a 72 I am using a drum perch from a 73 suzuki gt380 (sebring). I believe the perch was used on may bikes because the handle was listed as fitting like 15 bikes.
all you need really is a perch that has a swith for a drum built in most dirt bikes from 70's ran drum fronts and are 7/8 handle bars. I have yet to wire it up but, two wires replace two wires I can't imagine it's that difficult.
I found the perch on ebay for $7 and the handle I got through gdlcycles.
good luck
Cool - sounds like we're building the same sort of front end. My front hub is from an XS1b laced to an 18" rear alloy XS650 rim.
How does a front drum acuate? Ive never owned a bike with front drums. Is it a cable like a clutch cable?
Correct. There are usually two pads - side to side. Depending on the bike one spring tension may be softer then the other one. This way you can have 2 stage braking.
As you pull on the cable, it presses one shoe to the inner wall of the drum. As you continue to pull the cable the second shoe presses against the drum.
There are two inherent issues with drum brakes:
1) Heat - Drum brakes get very hot. The more you use them without letting them cool, the hotter they'll get, and you may end up with tempoirary failures from the drum expanding out from the heat.
2) Strength required - Because the only thing pulling on the brakes is the strength of your hands, people with weaker hands, or tired hands simply will not have as much braking strength and therefor can't stop as quickly.
Yes sir. do you have any pics since you tossed the old frame did you have to scrap the front end as well?
Oh gosh, do I have pics! You can read and view the last 10 months of my build here:
http://dotheton.com/index.php?topic=448.0
I haven't tossed the old frame just yet. I am picking up a 1978 frame, but may still use the 1972 just yet. I really just need to make new alloy plates which is easier and a lot cheaper than cleaning up, welding and powdercoating a new frame. The benefits of doing a new frame are significant though.
I did my current frame before I had my seat for example, so while I can mount the seat easily enough, with a new frame I could have the exact seat mounts welded on for a perfect easy clean install. So, I may still do it. We'll see.
The front end is no big deal at all. I already went to a 35mm front end, which is stock on the 1978 frame. I modified the lower triple tree stem to match the 1972 frame, but it's just that one part. Just need a stock 35mm triple tree and the forks etc. will go right on no trouble.
Check out my thread - more pics than you can shake a stick at, and lots of my front end (the bike that is).
