Building a dream cb 350 engine
partydog
Ok I'm building my cb 350 twin for the track..I'm not concerned with any club's rules. What is your dream build...just engine wise. With or without machine work.
This will be a track day weapon that I do not want blowing up on me..feel free to chime in with suspension ideas.
If you're planning to race then you'll want to build to suit one set of rules or another.
If you're looking for a track-day outlaw then that's something completely different and more fun in my opinion.
How wacky do you wanna get?
Nothing too crazy, reliable and peppy: Stock internals; optimized
-Pistons balanced to lightest, rods balanced to lightest, crank knife edged, full rotating mass balanced as a whole and cryotreated
-Head rebuilt; oem spec swirl polished and slightly undercut valves, head shaved .015-.020", ported with attention to small radius
-Coatings: Piston domes, comb. chambers, valve faces and exh. ports ceramic coated for heat control. Piston skirts, rods and crank get anti-friction coating (helps sluff oil too)
-Electronic ignition
-30mm Mikuni VM carbs and large pod filters
-Good quality exhaust, free flowing mufflers; wrap pipes in heat wrap to improve scavenging via exh. velocity
-OEM cam degreed, tune the whole thing on a dyno to most power
Definitely racy, somewhat evil: Everything above plus....
-Aftermarket (or good regrid) camshaft
-32-34mm mikunis
-Barnett clutch kit
-lightened flywheel
-Hotter coils, nology wires and good plugs
-may need to beef up the charging system to drive the coils, will most certainly want to beef up the wire harness
Totally Bollucks!
-Forged pistons and rods with rebalance
-Full race porting with oversized undercut valves(big bucks)
-Full race cam; Megacams etc
Stoopid:
-no charging system, wire for total loss with stout gell cell
-shave more off head, build for 11 to 1 compression
-race gas (see above)
Swagger that is a great start for me. I work at a shop so parts are coming in at a great price..I will most likely outsource the labour..maybe..so anyone can PM me with quotes. I have two engines right now and am planning to buy a third if anyone is selling.
so the first engine will be the light hearted one and i will be paying attention to the chassis/suspension. The second one will be the more evil where I try to fit some other front end and possibly rear . I don't care about vrra rules..this is my hooligan bike build for track days. So any suggestion on chassis and control mods will be taken into consideration.
Glad it helped a bit, I've built a couple but take a look at Roust's thread above, good info there..
