Camshaft cl350
If you go with a performance cam, than you need to build a motor that works with it. Theres a lot that goes into properly building a top end. Sure, could you just toss a cam in and run it, ya. Will it ever perform as well as it could? I doubt it.
Megacylce Cams - great recommendation. Go for the mildest Street and Track grind. Race grinds are slower on the street.
The motor would also benefit from higher compression/larger bore pistons and porting the head, but a simple cam change will make it feel faster. You really need new valve springs to go with that cam, and maybe while you are there, a valve job might be a good idea.
Ya man... You should really look into a port and polish as well. Get the head worked on a flow bench. If your going with a performance cam, letting the head breathe easier will be super noticable in the power realm. Also... Look into getting a set of Mikuni VM30s. Instant power adders for the 350 and will make tuning 1000 times easier.
Also... The CL model already has a better cam and top end than a CB model. You can actually just have headwork done on whats aready there and be ahead of the game.
you could probably lose the base gasket, rering, lap valves properly, slot cam sprocket and degree cam properly and double check valve to piston pocket clearance and you'll be surprised how much faster your bike is, then start playing with cams, race valves/springs, overbore, higher comp pistons, and porting... as far as porting too, I think I'd avoid it on the stock 350 head, if you open the ports much you'll probably lose a lot of intake gas inertia and your top end might actually suffer
That raises a really good point. By now, we all know that "port and polish" doesn't really mean polishing the ports all nice and shiny, but porting is also often misunderstood.
The key is to match all the different sections of the port so they work well together and the idea is to maintain port velocity and not just go for huge flow numbers. I'm rather anal, so I get the baseline flow numbers and then measure the ports at several key spots. Then I sit down on the computer and work out what port shapes and sizes I'm looking for. Vizard and AG Bell have the data on that.
Then I run the data through the Engine Expert software and double check my assumptions. Then I get someone who has a steadier hand than me to port it to my specs and get it flowed again. Then I try to work out which cam will work best with that flow profile. And so it goes.
On a street bike, I would just clean up any sharp edges taking care to not remove any more metal than was absolutely necessary. A good 3 angle valve job on a Serdi is always a worthwhile investment though. IMHO.
if you think you can add a cam and gain power, you dont want a cam in your engine. a lot goes into designing a head... lots of time.
as others said... start small. if you want a high revving cam, get one off a 1969 cl/cb350... hard to find (and usually pricy when you do!) but they are out there.
but for now, i say take the head apart. dont grind ANYTHING unless if you know EXACTLY what your doing. its much easier to ruin a head then it is to improve it. lap the valves, adjust everything to spec. if you ditch the base gasket (and run a different kind of sealent down there) your going to have to degree the stock cam sprocket, or buy a degreeable one.
also... start with outside of the motor first. do you have a performance pipe on there (2 into 2 or 2 into 1... stock is SUPER restrictive, and HEAVY)? do you have an electronic ignition (tons of power to be had, and reliability!)? vm30s can make more power, but HOURS go into tuning them right. i really do mean HOURS. if you dont know what your doing, your not gaining anything using them. do these things first. make sure everything is properly adjusted. if you still need more power, then look at getting some head work done.
just dont expect to have a decent upgrade in power without dropping at least 1000 dollars on the head... maybe a bit less if you do your own work (and dont end up ruining the head!).
Or take your time and just clean it up and get a valve job. ROCAN is right that to get the maximum benefit, everything must work together as a system, but I didn't think that was your objective just now. That head is pretty bad as stock but don't get a dremmel into the valve seats and make a mess.
Pipes are worthwhile but most lose power and add noise on a street motor. Adding a cam is only one step in a process, but as I said before it has the potential to make the bike FEEL much racier as it comes on the cam.
Funnily enough, I spend ages getting race bikes to run a smooth as street bikes. It's all about attention to detail and taking time. We all learned somewhere and it's not as if a CB350 is exactly rare or irreplaceable.
Go have fun
Can anyone explain a little more in depth about how to lap valves and degree stock cams properly?, or there somewhere I can go to read more on it?
I used a SL350 Cam. It has a longer intake profile and bolts right up. It adds some kick but is still perfectly manageable. If you go too crazy with your cam the thing will suck on the street. I also did a 3mm overbore, ported (well, really cleaned up the rough spots mostly) the head, Tsubaki cam chain, and KA Performance tensionor. It's working out great so far.
