Can't get her started - 1978 cb125s
maireeka
Active Member
I've had it running a few times, but it just won't start for me anymore.
I checked for spark by holding the plug against the head, it has spark when I turn it over.
After I cranked it a bunch of times (til i got tired of kicking lol), I pulled the plug and it was wet with gas.
I've got some pics of the carb, I'm not sure which screw is air, which is fuel. Maybe the fuel screw is too far out?
Maybe my float isn't set right? I really don't know.
Here are the carb pics
I think the screw on the right side of the carb that controls the throttle slide is the air screw, and the screw on the bottom of the carb on the engine side is the fuel screw.
What kind of settings should I have when I'm trying to get this thing started? should I tighten up the fuel screw since it's flooding?
I hate carbs.
I hate carbs.
If there's that much gas in your cylinder check your float height and the flow valve in the bowl. Sounds like there is way too much gas in your bowl. I have the same carbs practically on my CB175. The mixture screw matters, but not enough that it wouldn't start... If anything it starts easier when too rich (ie with choke).
With mine I usually do full choke, and crack the throttle while the engine is cranking over. Once it fires up I turn up the idle and gradually open the choke.
If you didn't mess with the carb settings before, and it was running then, don't mess with them now.
Much more likely that you have a spark problem. You say you have a spark, so check the timing - it can go off if the plate isn't tight, or through wear. It's a bit of a pain getting to it, lean the bike against something and work on the uphill side and you can do it without getting oil over your shoes.
You might also try disconnecting the headlight if your battery is weak - that'll help with spark voltage.
It never really ran right, it sputtered a lot and didn't perform under more than 20% throttle. I've messed with both screws a bunch since then, so I definitely need presets.
I'll try to figure out how to set the float, it's probably off.
Put the carb back on, empty of fuel.
Turn the petcock on and do your thing to try and start it.
Turn the petcock off and take the carb off and keep it level throughout this.
Drop the float bowl and see if the gas level is to high(not at the top of the bowl).
If it is too high, the float is set wrong(you should have set anyways) or it could have a hole in it. or the float needle/seat is no good or dirty.
Not sure about that carb(check manual or I could download for you and check) but usally you crankem in and back off a 2 1/2 turns.
Paul
so where should the gas level be in the float bowl? about half to 3/4 of the way?
thanks for the help everyone, hopefully I can get the float set and get her running good.
paulb said:
I would think you are pretty close at 3/4 full.
Good luck
Paul
Hey man,
Your float is supposed to be set to 21mm. Check out this Vid, it explains exactly what needs to be done. It's a CL175 but very similar carbs
http://www.youtube.com/watch?v=4itdYt90RAI&feature=related
Cheer,
Guy
great vid, but one thing i didn't get out of it was what are you actually measuring when you set the floats to 21mm? is it from the bottom of the carb body to the lowest part of the float or what?
Its kind of tricky, but you flip the carb upsise down, not completely, just untill the tab on the float rests on the float needle without pushing it. Then you mesure from the bottom of the float to the edge of the carb housing. Bend the tab up or down untill you get 21mm.
A quick google search yielded this page which seems to show pretty well what needs to be measured.
http://members.dslextreme.com/users/bikecliff/images/carbspec_float_height.html
your bottom screw is fuel mixture at idle,it's a keihin,,,,,junk! I own a 82 S replaced the carb with an earlier model keihin,,,idles like shit!! when the price of gas jumps in the future and I decide to commute with this bike,,,,,,,,,I'll fit a mikuni :o
Any idea for a base setting for the idle fuel mixture screw?
I got it running today, by the way. After checking the fuel level in the bowl, I found that it was about overflowing. I lowered it by bending the little tab, filled the bowl with gas, and it cranked up on the third kick. when I get my new petcock in, it'll be time to take her for a ride.
Well that's good news.
To set the mixture screw, what you do is turn the idle screw (the one on the side) so that the idle raises to about 2000rpm. Then you mess with the mixture screw one way or the other, and you will see the RPMs rise and fall a bit. The screw is set right when the RPMs are at their highest. If you notice that things are getting better when you get to the end of how much you can turn the screw, something is wrong and it'll be time for a rebuild of the carb. Most likely this will work fine if everything is clean and now that your float is set right.
When you get the highest RPMs with the mixture screw, lower the idle back to normal, about 1200rpm and you are done.
Cheers,
Guy
I commute with my 37 year old keihins that have never been rebuilt, other than cleaned, and I get 80mpg. Starts first kick everytime.
They aren't bad, but they need to be adjusted often.
I got it running again today after I installed my new petcock. I tried to set the fuel screw (it was fully tight when I started the engine), but it bogged the engine down if I loosened it at all.
This leads me to believe that my floats are still too high, causing a rich condition at idle. I'm going to fool with the floats some more next.
I did ride it around the block anyway, (hey it was running lol), and it ran like shit. Bogged with any amount of throttle, didn't want to rev much, died easily.
It was starting on the first kick though, and that's a lot of progress compared to how it was before.
Sounds like you are getting closer but still running very rich. Did you set your float to 21mm? It's one of the most important things in your carb. Any issues with your choke? Could the little window be lose and falling in place when it shouldn't? Tried taking the air filter off? Maybe it's clogged from sitting in a dusty garage or something.
Might also want to check your ignition timing and spark gap.
Cheers,
Guy
plug and points gaps are both set.
timing hasn't been touched.
Floats were not actually set properly, I still need to measure it out. It's probably the problem.
Air filter and choke are both removed, actually.
