Cant get my CB378 started. Timing?
mktsc
Active Member
So in over the past 2 years, I've taken the sage advice of one Mr. CrazyPJ, and gone the 378 route with my old CB360.
Just buttoned it up, and went to start it, and no dice. I marked the timing plate before I took the bike apart, and put it back there as a good starting place. I'd get nothing. Every 10 or so kicks, I'd get a pop or backfire out one pipe, but that's it. So I went through the timing routine again. The points were way off, so I set them, checked them, and checked them again. Same thing, doesn't even try to start, a loud pop or backfire every 10 or so kicks.
One thing I noticed was that the timing plate was probably 5 degrees off from where it was the last time the bike ran. I have spark on both cylinders, and even pulled the cam cover off to make sure that the cam is aligned with the proper timing mark on the alternator per the factory shop manual (it was).
Another variable was the fact that I put year old gas in it, but I figure it would at least sputter or try to run with bad gas. My next step is to try it with ether, and replace the gas with ethanol-free fresh stuff from the local marina. But I figured I'd check here to see if anyone had any bright ideas.
Carbs were tuned by ol' CrazyPJ himself, so I have a fair amount of confidence in them at this point.
Thanks in advance.
For reference:
The points adjusted when the bike ran before I took it apart:
The points adjusted as the bike sits now:
Just for kicks, the bike before I put the seat and tail light on it:
Something is off on the timing....I never go that far on the points plate.
My bike properly timed (But OLD Points):
Start off by dumping any old gas - responsibly and clean out the carbs again if they sat with gas in them for more than a few months. And fill with fresh gas and see how that goes.
I agree, something seems off because of where the points plate is when it's adjusted. I cant figure what it could be though?
I've purged my tank in lieu of fresh gas, but wanted to get the timing figured before giving it another go.
-MK
Little update. Found a few things wrong. One of the coil wires had come undone. Might've been when I pulled the tank off, but still needed fixed. The other and more significant find was the advancer plate. It was completely stuck, and wouldn't budge at all. After I put a good one in, the points lined right up where the mark from teardown was and open and close as they should.
So I reassembled the bike, sprayed some ether in the throats, and kicked away (no more electric start, kick only). I got what felt like kickback through the kickstart pedal, and a few hiss/pops out of the carbs. I got a pop out of one exhaust pipe, but other than that no action whatsoever. I pulled both plugs and verified that I was getting spark.
I'm not sure if this behavior is indicative of anything, but I called it a night. Only other thing I can think to do is pull the timing cover again and check that I'm getting spark on the right side at the right time. I suppose I could've gotten the coils hooked up backwards firing the wrong cylinder...
A few other things to note, are that I'm using the Kohler regulator/rectifier, and I'm also using a Dyna ignition booster. I'm not sure if they have any bearing on anything, but it's worth noting.
-MK
I think I'm going to pull the tappet covers and triple check that the intake on the left cylinder is closed when I time it, and that I'm getting spark on the correct cylinder...
-MK
Well I verified that my timing was correct, as well as my valve adjustment. I swapped plug wires and sprayed some ether in the carbs and the bike fired right up. Swapped coil leads and put the plug wires back on the correct cylinders and again, with ether the bike fired. I was able to keep it running for about 15-20 seconds while working the throttle, but the bike wouldn't run on it's own. It also wouldn't idle without me on the throttle.
After some fettling, I couldn't get it to run on it's own.
Logically I would say I need some carb adjustment, but the carbs were modified by PJ who's done more than a few sets of 360 carbs.
Ideas?
-MK
Are your carbs clean? How is the float height? Are you getting fuel to the carbs?
Sounds like a no fuel issue if it starts right up on ether.
Gorgeous I love the old tank. Im having similar issues with possibly the timing on my the left cylinder of my cb. Why do you call it a cb378?
Because its been bored out to 378cc's ;)
Carbs are clean, freshly rebuilt, and synced. It does sound to me like a no fuel issue as well, although with them being freshly rebuilt, I can't figure why.
It's now 378 from using pistons from an early 80's Suzuki GS850G. Essentially a 2mm overbore that maintains the same deck height, wrist-pins, stock rods, etc. See this thread:
http://www.dotheton.com/forum/index.php?topic=11736.0
A pic from the front. The bike was put together over the course of about 2 years in my basement. This was shortly before I rolled it up the stairs:
-MK
Did PJ work on your carbs before or after you left gas in the bike for months?
Do you have good flow from your petcock?
When you try to start the bike, and you pull a plug, is it dry? If it is, you're not getting gas to it, which means the problem is before the sparkplug.
Just to follow up, I drained the bowls and re-primed the carbs, and the bike runs great. Still a little tweaking on the idle settings, but I've ridden it two days in a row, and it kicks right over and runs strong.
The bike is so nimble and light, and feel really strong. PJ did indeed modify my carbs, and in conversation with him, he suggested rejetting with my current exhaust setup. He also indicated I'd pick up a lot of power by extending my pipes to the rear axle. I'm going to install baffles into the open head pipes, ride for a bit, read plugs, rejet, etc.
The bike is intended on being a continuous work in progress, always being honed and dialed in.
Thanks again for the help and support with this 2.5yr project.
-MK
Tell me your not riding with open velocity stacks and no rear fender.....You just did all that work, and risk an ingested stone or debris?
The other pet peeve is no fork brace.
Besides that, lovely looking bike.....
Screen filters are buried in the throats of the velo stacks, I'm fabricating a fork brace as we speak.
Thanks!
