filteredsoul
I'll try to be as articulate as I can here...
I'd like to know if adding a capacitor to my electrical system will do what I want.
I'm building a kustom Suzuki GN400 in a minimal/boardtrack style.
Normally, this bike uses 6v electrics with a "balanced" electrical system.
Since the bike was derived from an enduro bike, you can remove all the lights except the headlight and ditch it.
The headlight will run with the engine running, but no battery, charging system, etc.
Basically there are 2 coils on the stator plate. One provides the power for the CDI / ignition / engine.
The other coil has 2 wires coming off it. Together they supply 6v of power to the bike. By "blanking off" one of the wires,
the other jumps up to 12v -ish. Of course, this is non-regulated AC power that increases and decreases in voltage as the engine
revs rise and fall.
Since this bike will never be ridden at night, and the only electrics I need to be legal here in NC are Headlight, brake/tail, license plate light and horn I was debating on how I was going to power all that.
Option 1: Total loss. Find the smallest battery that would power what I have on the bike for 2 hours. (my decision. I'll probably never ride it for more than 2 hours at a time.) Plug it in to a battery tender when I get home, and top it off for the next ride.
Option 2: Run the electrics off the magneto. I know my bike doesn't supply a ton of juice for lots of lights, but I figured if I go with a "scooter" headlight (35w) and a regular brake/tail incandescent bulb (don't want LED for this application) and LED license plate screws/lights. The horn won't be an issue... I'll hardly ever use it... again, an AC scooter unit. I figured I'd get an AC regulator to prevent bulb melt-down, then carry on the power to my individual components.
My concerns with this option are: Waiting at a stoplight, my lights will be dim and possibly flickery due to the low rpm's correct? Will a capacitor "smooth" things out? I don't want to get hit from behind because someone didn't see my lights.
This would be my preferred method because the bike would be low maintenance... no battery, no charging, etc.
Any thoughts/ideas?
If you want to see the bike so far, check out:
www.kustomgn400.blogspot.com
revs rise and fall.
Any thoughts/ideas?
