Carb Issues? Fuel Issues? Spark Issues? Probably All 3
I'd check hondatwins.  I know I reposted some stuff from the old 450DOHC group about it.  You have to do it while the engine is stone cold so I thought it would be something to do while you are waiting for your stuff to arrive.  HT is blocked at work for some reason so I'll see if I can find the thread when I'm at home tonight.  The only special tool you need is a feeler gauge which you can get pretty cheap at most autoparts stores.  You just have to make sure you get one with the right size as the clearances are pretty tight.  They say in the thread what clearance to use.
I had to take my carbs off to get the intake valve cover off.
And I was kidding about it being fun.  :) Although it is educational.
Excellent... I got some carb cleaning solution... don't have a feeler, but could go get one.
I'll take a look at hondatwins! Thanks!
After a tank cleaning, new petcock, and a new clutch cable... she's running again! Now time to mount the clubmans and keep moving...
