Carb on my TL 125
AzHonda
Coast to Coast
Have a question.
On my Honda TL 215, I took the carb off and cleaned it and the shaft that the throttle cable goes into will not go up and down in the cylinder that it goes into. I literally will have to push it down with my finger. Is this a part that just needs to be lubed with fuel to work properly or do you think something else is wrong? It went up and down no problem when I pulled it off for the cleaning.
It's the part marked #8 and the spring above gives pressure to keep it down but there is just to much resistance for some reason.....
OK, nevermind. Got it figured out. Broke out the manuel and realized i assembled it wrong. Should of just read the manuel in the first place. Please delete thread.
