Carb slide damage
dp9
Coast to Coast
I tooke my carbs apart for the first time and found this. what could cause these scrapes on my carb slide? they're relatively deep. the other slide is fine, the bike isnt running great (but its not fully tuned). any thoughts? anyone ever see this before?
which side are those gashes faceing, the filter side or engine side? Were you running it without a filter? If I'm guessing it could have been the previous owner trying to tap it free, there's no way any particles could have created those gashes without destroying your engine as well. In this case, they should be on the filter side. Tell me, the carb diaphragm cover screws are Philips? Are they stripped? This would also be a telltale sign of PO 'abuse.' I'm saying this because they're actually JIS screws, common on UJMs, and you can get away with using standard Philips head screwdrivers but people who don't recognize that are the ones that damage the screw heads... and possibly try chiseling a slide free...
you guessed it, the damage is on the filter side. I was not ever running without a filter. The diaphragm screws are not stripped, even though I am using a philips head screwdriver on them. didnt know they werent. good to know. and even though I didnt know that, I didnt try to chisel the slide free ;D (wasnt stuck, that i know of).
Definately looks like it was hit with something, probably a chisel for whatever reason. Or it might have been in the bottom of a box and an engine case was dropped ontop of it, or maybe put into a vice or something... Generally slides are made out of brass covered in chrome. Pretty easy to damage them.
hmm, so at one point it was most likely stuck, and then forcibly freed. think i need to replace it?
I think you should be ok. Those sharp edges arent chewing up the body of the carb, are they? The cuts dont go straight across so it shouldnt change the amount of air flow going to the engine. It will change the weight of the piston very very slightly (so it lifts easier) but i doubt you would ever notice... Unless youre going for max power and are going to race the bike, i think for street riding it should be ok. Maybe if you can get one for like 5 dollars, for peice of mind, otherwise id just leave it.
I had to disassemble my (LH) carb again as I am still having cut out issues and after seeing your post I was sure to check. I have the same marks on mine (from the filter side). So at some time we must have shared the same shade-tree "mechanic". Must have been the same guy who CLEARLY dropped my carb ON THE FLOATS! ???
WTF? :o
alright, so it looks like damage from a shadetree PO mechanic :-[
Those floats look serviceable though, shouldn't cause any appreciable performance loss (they're below the gas leve)l.
^ Upon further disassembly and inspection BOTH floats have gas in them. The one in the photo (most damage) has a HUGE gaping hole in it, and the opposite side has a small leak at a small dent.
Perhaps this is where my running trouble is...ya think? Not to mention the drop must have whacked the WAY out of specs!
absolutely. Are you saying the floats are damaged beyond repair? you might be better off purchasing OEM replacements...
midnightcafe said:
...you might be better off purchasing OEM replacements...
BTW, sorry for the hijack. ;)
Sadly that would seem the best option. I actually looked and the leaks under a microscope, and one side seems to have corroded from the inside (at the very bottom) and the side with the most damage is right on the crease. So although I could do a hack solder job I fear it would be a Band-Aid on a severed head. I have NEVER had any luck soldering anything with any precision even under ideal conditions and I could see this attempt going south very quickly! :-\
np. speaking of floats... what part of the throttle application does float height affect? like 1/4-1/2 turn, idle-1/8 turn.. know what im saying?
