Carbs cleaning and tuning HELP?
Bobby4Prezz
Hey guys im working on my cm400 build, and i;ve never cleaned/rebuild or tuned carbs. the guy that owned the bike before me thought it would be a good idea to spray bomb the whole bike flat black and alot got on the carbs, the choke cable was broken on it so i was also curious about fabing up a choke lever to have on the carb apposed to reduing a cable. ANy help/Link/Videos or other threads you guys can point me to would be great! thanks all -Bob-o
Heres what you do. Go buy a liter of lemon juice and a huge stainless pot from a thrift store. Fill the pot half up with water, dump in the lemon juice, put it on the stove to boil. While youre waiting, strip the carbs down and get all the little rubber bits out, all the jets, floats, everything. Once the waters boiled, dump the carb bodies in there for 15 minutes. Check em and see how clean they are versus how the bodies look (the citric acid in the lemon juice will eat away at the aluminum bodies of the carb a bit). If theyre not clean, put em back in and keep checking every 5 minutes. You wanna get them as clean as possible while minimizing the corosion.
After, get a can of carb cleaner, a toothbrush shaped wire brush, and a regular hard bristle tooth brush, and go to town on them. The carb cleaner will eat that black paint no problem combined with the wire brush.
