CB 350f rearsets without rear tabs?
fluke12
I got a project 350 four cylinder that had the rear tabs already ground off by a previous owner. I’m guessing he was looking more for a brat build but ran out of steam.
Anyone have ideas of rearsets that’ll work or am I going to have to find someone to weld the ears back on for me?
A picture might be helpful.
If there are bosses still on the frame you may be able to bolt up a plate to mount your rearsets to. I welded mounts for the rearsets on my 360 frame because the passenger peg mounts were not in the ideal spot.
It’s a messy garage but hopefully you get the idea.
In digging through the boxes of things that came with the bike these more current controls were in there. No clue what bike they came from.
Yeah, I’d say some welding and fabrication will be required. You have nothing to mount them to.
No need to apologize about the garage. Mine’s 100x worse.
Anyways, the rearsets look like mid-90’s Honda pieces. Maybe Cbr600F2 or F3?
Later, Doug
Thanks for the heads up on what these rearsets may be!
I’ve been reading and it sounds like the 350f and 400f have the same frame which means there may be some rearset options for that bike.
I’ve seen a few 400s that come off of the swing arm bolt and maybe an engine mount bolt as a mounting point for a plate without welding to the frame. If anyone knows anymore about that, it may be something I try out.
Find some of these and have them welded on where ever you need them. That's what I used on my 360 and they worked great.
EDIT: I got them from LowBrow
