cb 550 carb issues, help needed
shiznits75
Revive custom motorcycle fab
Ok, so I rebuilt my carbs and one of them is pissing out gas from the over flow tube on the bowl. it only does this after its been running and I shut if off. When I rebuilt the carbs , the floats seemed to be ok. I shook them and there was no gas inside of them. The same carb was doing it be I rebuilt them all. Also the idle goes up and down while running. Any ideas would be greatly appreciated.
Check to see if the brass overflow "pole" in the carb bowl is cracked...even a hair line crack...
If it is, no matter what you set the float level at, it will leak...
If the brass poles are OK, it does seem like you have dirt stuck between the float needle and its seat...
Id remove the float valve and just blow some compressed air into the seat..
