cb 650 idle trouble
stein514
Hi, I have a 1979 cb650 and I did a lot of work to it. new piston rings, honed, ported and polished head, ect. the bike runs, but doesn't seem to idle without the choke pulled a little bit. I cleaned the carbs and thought everything is fine. but now it runs rough and sputters. when placing my hand on the air intake, it revs up a bit and runs smoother. I adjusted the pilot jets as specified in the manual. is one clogged? I checked the timing and that seems right. the floats are also set to specs.
a friend told me I could go with Mikunis from a KZ650 or similar. any ideas on that?
If you cover the air inlet and the bike idles up and runs smoother, youve got an air leak. Spray all the connections and hoses with wd40 and see where it is.
Might also be running lean (choke helps it run better by reducing air), but find the leak first before you think about rejetting.
New carbs wont help at this point.
