zimfistofdoom
So here is what I have replaced so far in converting my 1972 CB100 to 12 Volts:
-stator
-regulator/rectifier
-ignition coil
-capacitor (Kickstart, replaces battery)
-bulbs and whatnot to match the 12 volt system
Here is the problem:
I can get it to kick over and start, but the idle is very low and as soon as I start rolling on the throttle it stalls out. Before the conversion it ran fine, started on the first kick and ran like a champ. I'm undergoing this project so I can have a headlight that is useful at night....
I tried adjusting the carb, but that seems to be to no avail. My initial thoughts are timing adjustment, tappet adjustment or spark plug gap, but I would like a little insight before I do any damage.
Has anyone out there done this conversion or something similar? Any and all information would be greatly appreciated. I haven't been able to find a definitive guide for how to do this conversion, so I plan to put one together (once I am successful in the swap....)
-stator
-ignition coil
