CB160 missing oil filter stuff
redwillissuperman
Keep it simple- engine, wheels, bars
I seem to be missing some stuff in the hole here on the CB160. I think the rotor is on backwards. Not too sure what else?!? Filter? I think there is a snap ring. Gasket(s)? Correct bolt? Bolt seems too long with the rotor flipped properly.
The part in that second picture is inside out. The thread is to remove it. Take it off and slip it inside the part in the first picture and retain it with a 6mm screw. Just like the parts book in fact :-)
I personally don't have any experience with the CB160, but I have been in a couple 350s.
I believe those additional parts are on the back side of the clutch basket. It runs the plunger in the oil pump.
It's really simple.
Housing #16 slides over the end of the crank and is retained by lock washer #31 and castellated nut #30.
Rotor #17 slips inside housing #16 and has a thin O ring #22 around it.
#17 is retained by screw #38 which screws into the end of the crank IIRC. #38 is a 6mm diameter screw and passes through the 8mm threads cut into #17. Those are there to aid removal of that part.
