L-ski
Active Member
first,I though I knew what I was doing when i tried to adjust my clutch today... I was wrong.
basically i cracked/shattered the clip that goes over the "clutch shaft thing" while tightening it down.
second, what is the proper way to adjust my clutch on my 1972 cb175 since this obviously did nothing but stall my bike out and then i broke the clutch adjuster piece while re-assembling.... must be working out too much.
The reason for adjusting the clutch: when i have the clutch fully pulled in and put it into gear, the gear engages and the wheel starts to spin before i let the clutch back out.
I was turning this big screw after loosining the upper bolt holding the piece that i eventually broke...
thanks in advance for any input
