need4steed
Active Member
i have turned the internet insideout and have found lots of things to check, but nothing has worked. My cb175 will not idle on the left side. the bike is stock and has nothing modified on it. Here are the settings. The idle screw on the right side is 4-5 turns out and idles great. The left one is turned almost all the way in and will sputter and then rev real high. When i back it out just a very little bit, the idle will go back down (1600 RPM) and the left side will not fire. It will fire when i rev, but at idle nothing. I rode the bike around and it fires and pulls pretty good. there are a couple of spots where it misses. Also, when i go to hammer the throttle it almost stalls out and there is no response at all.
I checked the float hight.
I have cleaned them 3 times.
Checked for air leaks. None.
new spark plugs. What should the gaps be?
Timed and valves adjusted.
Slides are installed correctly.
compression is good.
But here is something that has me scratching my head. When i back the idle screw out on the left side to match the one on the right with the choke fully applied it idles perfect.
thanks for the help.
