cb175 won't start :( please help.
pat_00
So i've been tinkering with my cb175, I bought it not running. Apparently it was on the road until 3 months ago.
So far i have:
Adjusted the plug gap, tappets(.002), points gap(.014) and timing (statically set to spark at the 'f' mark on the generator cover)
Taken the carbs apart, cleaned them and checked the float height (20mm apparently it's supposed ot be 19.5) everything looks okay.
It seems to have compression when i turn the engine over by hand. It also seems to pump air out of the exhaust when turning with the starter motor. I know these are lame tests, but i don't have a compression tester.
I pulled the spark plugs and held them against the head to see if i had spark. It looked okay except that the right plug would spark weak 4-5 times to every stronger spark.
The furthest i got was a couple of pops from the left cylender.
An ideas or suggestions, I really want to get this thing running and on the road.
make sure your battery is fully charged... gas is getting to the cylinders and/or carbs AND if need be make sure your coil is getting as close to 12V as possible.
Fuel is definitely getting to the carbs, thanks for the suggestions, i'll check the coil voltage and charge the battery. I have a hunch it's an ignition thing. The coil looks like the original one, i might replace it.
