Left side is cold on idle. But when I ease into the throttle at about 1800 it jumps to 3k and the left side pipe starts to get hot. I cleaned carb, set float level, points timing adjusted, air fuel mix to spec, plugs changed, battery at full charge (didn't put a meter on it while running but it was at 13+v before i installed it ). Tomorrow I was going to check valve gap and cam chain tension.
Also when I spray started fluid in the intake it still does not rev up. This tells me it is not firing at idle, correct? Or is there something else I need to check?
