cb350 center stand
72cl350cafe
i just finished a cb350. and i've run into a problem of the center stand not being long enough because of the longer shock. I was wondering what others have done to deal with this problem?
If you just want the center stand for doing maintenance and such, you could just leave it off and use a rear stand instead. Just need to make sure what ever stand you're looking at is narrow enough for the swingarm as they are mostly made for modern bikes and are wider.
im running 13 inch rear shocks. I think it is a combination of longer shocks and bigger tires. I'm only running a rear stand because of rear sets so no side stands. thanks for the help
i was looking at it today and was wondering maybe are there rubber pieces on the bottom of the stands legs when it was stock?
I'm not sure about the rubber, but they wouldn't make that much of a difference. Maybe a 1/4", tops.
Have you thought about modding the side stand so that it would work with rear sets?
