CB350 foot peg crossbeam
ducmeister
Hi all,
Finally getting the project underway and I've removed the original footpeg crossbeam that goes under the motor. Do I need to replace it with anything or is the frame strong enough to live without it?
I won't be racing this bike but I am 6 feet tall and weigh nearly 190lbs (height decreasing, weight increasing).
Cheers,
Rob.
Good question.
I have removed this on my CB175 also.
Anyone have an answer?
I think I may put a small brace across mine anyway.
Cheers.
I'm pretty sure you're talking about the motor mount bolt that runs from peg to peg. It should be threaded at both ends. find some spacers and nice acorn nuts to finish it out, but I wouldn't run without it.
Are you referring to the 175 or the 350? The 350 is nothing like you're describing. It has a beam/brace/tube (call it what you will) bolted from one frame bottom tube to the other. It also has the footpegs and side stand mounted to it.
I don't believe the "step bar" does much in terms of frame reinforcement. It's mostly for the footpeg and sidestand mount. Look at the 360, it doesn't have one. I'm building a 350 without one and relocating the stand. Shouldn't be a problem.
Your relocating the kickstand? Im doing this as well. Was gonna start a thread about it. Are you keeping it on the left? Why are stands always on the left (or are they?)
I want to grind off all the tabs & relocate it forward alittle more with a homemade clamp. What are your thoughts?
I got a stand mount from Ebay but for some reason, the way it is made, it only works when mounted on the right side. Then when my project got started, I wanted to use CL pipes which are mounted on the left. So I thought it would display the pipes better if the bike was leaned to the right. Yes, you can cut off the sidestand mount from the stepbar and somehow weld it onto the frame with or without a clamp but make sure it's absolutely strong. Get a pro welder/fabricator to do that. If that doesn't work there are bolt on sidestands but I don't trust them. Can't give you a solid reason why they are always on the left, but I'm guessing it goes back to horse riding. When a rider walks or mounts a horse, he/she does it from the left side. The tradition just carried over, first to bicycles (chain is always on the right so it's away from your pants or skirt) then motorcycles.
EXCELLENT! Thanks for all the info guys.
I might just leave mine off the 175 now and just fab up a new kickstand mount.
I LOVE this site and it's members for info like this. What a great resource.
Cheers.
