cb350 overbore questions
hindesjake
I working on a cb350 right now and i'm trying to figure out what i should do to the motor to basically make it as built as possible but still reliable enough for an everyday driver. It will also have to be ran on pump gas. I've looked at piston kits and it seems like a 67 mm is strictly for racing but what about the 65.5mm? Also, what should I do with my valves, springs, cam, etc? Thanks for the help
hindesjake said:
....................o, what should I do with my valves, springs, cam, etc?
Throw them away. With a bigger bore you won't need them....
OK seriously, the stock valve train will work fine with a slightly larger than stock bore. You could probably clean up teh ports slightly while the top is off and make sure it's all in good condition, but there is no necessity to change cams or valves when you go up slightly in bore size.
You may find a slight improvement in mid range and possibly slightly flatter at the top end, but on the street that's fine.
If the budget allows for it, replacemnt valve springs and a good valve job are a worthwhile investment.
2 or 3 mm over isn't a problem on the street, it fact it's an advantage as it gives better bottom end power.
Just use lower compression pistons and itwill still run fine on 87 octane.
I bored my CJ250 14mm over (fron 246cc to 391cc)
Sorry if I'm jacking the thread, but what changes would have to be made with the carbs when overboring? Would new units be required or could you just increase jet size? How about float charateristics? After the engine is back together would it be a test and tune nightmare to get the mixture correct?
What would the 65.5mm increase the CCs to on the 350?
Ok thanks for your help. What are the specifications on what to bore the diameter to? Also how much should I leave to hone out?
What hone are you using?
If it's Sunnen or AMMCO you can leave anything from 0.0015" to 0.003", depending how accurate and smooth bore is done.
I've got some pictures of cylinder honing in my CB360 build thread (link at bottom)
I dont know what hone I'm going to use. Which hone is recommended?
This will be my first time doing this. I'm a fairly decent machinist, I just dont know the steps i basically need to take to complete this. So basically I buy a bigger piston and get the rings for that piston. So say Im putting a 1.5 mm overbore piston in. Im going to need to bore the cylinder to the exact diameter of the piston and rings to get the exact fit, which in this case would be 65.5 mm, correct?
You sure you want to do this?
AMMCO hone is about $500.00+ new, little cheaper if you find one on eBay.
Sunnen about the same price last time I checked.
The 3 leg spring hones are only for cross hatch and do nothing to size bore correctly.
You should be looking for 0.0015"~0.0017" piston to cylinder clearance (I'm assuming you already have a bore gauge measuring to 0.0001"?)
Measure the piston about 10m up from base 90 degrees to pin.
It will be undersized.
Bore about 0.002"~0.003" undersized
The bore will be very close to 65.5mm when finished.
If you can bore dead accurate, square and parallel, with around a 10 micron finish (don't know the micro inch finish) you could get away with just boring and use a flex hone for cross hatch
(highly dependent on machine accuracy)
I've been doing this since around 1974 and taught hundreds (if not thousands) of people to bore to a 0.0002" tolerance
And it should go without saying that you bore each cylinder to match the specific piston you're using, once you have them and can measure them yourself. There may be slight differences in each piston from manufacturing. Maybe not on a super-high-end fancy piston, but on mass-market pistons I think you're into some slight differences.
What are the plans for the cam, head porting, valves, suspension, braking etc? You're best to spread the money around vs. building a super hot rod engine that sits in the stock frame with basic suspension etc.
WOW! I had not clue that those hones were that expensive! The machine ill be using is a German machine called a Hermle. I will be able to bore this within the accuracy of .005mm, which is about .0002 inches. I think i will be worried about the surface finish more than anything. If i bore it .005 mm small, can i not just take a spring hone and remove the rest? I'll be able to check the accuracy of the parallelism and perpendicularity also so im not worried about that.
Don't remember ever hearing that name before?
Should be fine going 0.005mm under but, depending on tooling, you may be better off boring closer to size and just use spring hone to get cross hatch
It's really difficult to keep cylinder round and parallel with spring hone (not sure I could do it very easily and I've had a lot of practice)
Strangely enough, I was only talking about close tolerance machining this afternoon.
When I was machining we worked to a tolerance of -0.000mm~ +0.003mm on various components (it really sucked when they cut production times in half, wasn't possible with 'single point' tooling in the time allowed - it meant NO PRODUCTIVITY BONUS :(
If you using replaceable tips, the radius will dictate feed rate, usually around 0.004"/rev. (~0.1mm/rev)
You wont be able to take it all out in one cut as the liner is rarely tight enough in cylinder (and if you 'spin' it in block your totally SOL)
Center it up and try a 0.010"~0.020" cut, around 350~400rpm and see what surface finish you get, adjust rpm to get best finish, just get it pretty smooth then 'sneak up' on size
Surface speed will probably be well below whats recommended for cutting cast iron, but, it keeps cylinder cooler
Motorcycle boring bars turn relatively slow, I forget max and min rpm but it's not high
Dang dude! that freaking sucks about the three thousandths tolerance thing and them cutting the production time in half!
So what are you saying about going closer to size? Say my finished cylinder size is 65.5mm, I was going to bore it to 65.495mm and hone the rest out. .005 mm is nothing to hone out even with spring hone. Correct? What am i supposed to measure on my pistons before i start this process? Everyone says that each piston needs to be fitted to a certain cylinder. Wont the piston ring affect all of my tolerancing anyway?
you need to account for piston expansion, that should be specified in your service manual, the piston to cylinder clearance isn't all that critical as the piston doesn't provide any sealing, but it needs to be close enough to prevent slap and far enough to prevent seizing. if I were you, I'd bore it to the size you need based on expansion, and use a flex hone to crosshatch it. you really don't want to do a perfect bore job and then go screw it up with a manual hone, all it needs is to rough up the surface so the rings bed in and seal right
Just like roccity said you want to cut your cylinders to the pistons, your cylinders after honing should be the pistons measurement plus its recommended clearance...when you hear people talking about putting certain pistons in certain cylinders it is because new pistons will vary ever so slightly in size and a good machinist will measure each piston and cut each cylinder accordingly so you want to make sure that each piston goes in the cylinder that was cut for its specific size...as for the rings the cylinders are cut for the piston size plus clearance as mentioned above not for the rings so once your cylinders have been cut you will have to drop each ring into the cylinder and check the end gap (check it in a few places in the cylinder) and you will then need to file the end gap to the recommended setting for your engine. Do the rings the same as the pistons in that each set of rings will have their own cylinder. Rings generally do not grow so the gaps will normally be very close, we actually run almost zero gap on our top rings in our race engines here but I would not recommend that for a street engine so use the recommended end gap.
Measure the piston skirt, 90 degrees to pin, about 6~10mm up from bottom. (it should say in service manual)
I run about 0.0015"~0.0017" clearance as I only have an inch bore gauge (but as it's only a comparator it's not a problem)
You're going into relatively unknown territory so DON'T use factory clearance (I think factory spec is 0.0012"?)
You may hear all sorts of BS aabout using 0.002"~0.004" per inch of bore dia.
Basically, don't, that's the spec for ring end gaps not piston/cylinder clearance.
Piston should 'float' on an oil film when the engine is running
Piston to cylinder clearance is probably most important bit, not enough clearance and it seizes, too much and it rocks in bore and prevents rings sealing properly.
I check end gaps but so far have never adjusted them, usually use factory spec as rings DO 'grow' when they get hot and the gap closes up slightly
Ok so since i'm not using a stock piston, the thermal expansion of the aftermarket piston is going to be completely different as compared to the thermal expansion of the stock piston. Should I ask the manufacturers that im going to buy the stock pistons from what they recommend?
Also, is this the hone you were referring to? What grit should I get? etc...
http://www.google.com/products/catalog?hl=en&expIds=17259,17291,27615,27926&sugexp=ldymls&xhr=t&q=flex+hone&cp=8&um=1&ie=UTF-8&cid=15473363708856365981&ei=HHkJTaieJIL68Abb_7yqAQ&sa=X&oi=product_catalog_result&ct=result&resnum=4&sqi=2&ved=0CD8Q8wIwAw#
Do i find the appropriate ring gap from the manufacturer that im buying the pistons from?
Another i question I have to bump up the compression is, if I grind material off the head will this give me more power and compression and still allow me to run pump gas?
That depends on the pistons. Oversized pistons with teh same crown will raise compression because a larger volume of gas is being compressed. Some larger bore pistons are manufactured with smaller crowns to compensate for that and others have raised crowns to raise CR.
Old 2 valve motors can't stand a lot of compression because they have so little swirl and tumble and little or no effective squish/quench. That's why we try to machine squish bands in to all our race motors - to allow for faster flame propagation rates and reduced possibility of detonation.
