cb350 parts galore plus Cb500 forks and a random tank
halekai
Active Member
Hello Y'all
I am clearing out a bunch of things I may never use so if you could use them...
I am located in SF Bay area Walnut Creek to be precise.
I know some things get killed on shipping. Ill try and work with you DTT people. Consider anything over $20 knock off 40%
Link to CL ad for more detailed description of items.
http://sfbay.craigslist.org/eby/mcy/3735840740.html
SOLD...
cl bars with controls
cl front fender with divots
one of the cb350 front ends with upper and lower triples
one horn
more pics
Anyway to get a shot of the inside of the tank? Any rust (inside or outside) dents, scratches? If so where are the problem areas?
Not too worried about exterior damage as I'm shopping around for a tank to hack up, but if this one is solid on the inside and out I may just chop my tank and use this.
BTW are the petcocks still on the tank?
XSJado,
Hopefully you read my description of the tank. A cpl small dents. one rust pinhole in the deck. typical rust inside. I was going to hack it myself but I moved into a stock direction. Ill take the pics you requested. I dont know about shipping to AZ. I am not really experienced with shipping calcs so it may take a while to get.
The that and dents are alright. Where are they located on the tank (front/rear side/top) like I said I'll most likely be using it for a seat I'm building. If you take the tank to a UPS store they can give you an idea on shipping cost. Or you can take it down to the post office to get an estimate on shipping. Let me know asap.
I will include a petcock with that that needs a rebuild kit because the rubber has dried out. I will give you the tank for $20 plus shipping. PM me your addy and phone number. I can get to the post office on friday at the soonest to check prices. Ill have it boxed up and if I can contact you right from the office ill send it away.
CL350.
To the best of my knowledge it is a 68 or 69 based on the parts that were on it. Motor had "type 1" cover on it. Had semi-round tail light. Scrambler pipes. Scrambler tank. Rims had "extra" divots between spoke holes. Read the description in my link. No title. No vin stamped on head tube. Only barely readable CA EPA badge that does have a vin.
Relax-ima-doctor too!
I did sell one set of bars today with controls. not sure if I have another set. Ill look tonight and get back to you tomorrow.
unfortunately no carbs.
I did an inventory today and I do not have an extra set of bars with controls. I will update the list with what is sold.
