CB350 Rear Sets
Easyyyyy fellas.. I get enough of this girly drama bullshit from my bitter ex girlfriend. I think your expectations for those rearsets were a little too high, but if you don't like them yeah return them. Rearsets in particular are something that ppl can "help" with but ultimately every bike frame/exhaust system/etc. is a little different so the mounting will be up to the user to be able to make it work.
I wasn't annoyed with this particular buyer. More-so that we have a clearly stated no return policy on our website. These do clear stock exhaust, and similar. There are several pics from several angles showing precisely the placement on the bike, on the thread I have on them.
I offered to exchange the levers for our new offset ones. The largest diameter of his exhaust can is directly under the levers, and said the offset would have to be 3+ inches. That isn't near stock. I can not guarantee that these fit every exhaust under the sun. While he was correct in telling me the max diameters are similar to a stock exhaust, the placement of those diameters are not the same.
I offered the guy a refund, which we don't typically do. This was close to two weeks ago, and haven't heard a peep. Then a friend shows me this thread and he's making me out to be a disgruntled seller. Not the case.
First, you offered me a refund last week. Not two weeks ago. Second, I have yet to see a set of these on a bike with the exhaust. Third, non folding pegs at the passenger peg spot is pretty dangerous. Lastly, I'm gonna keep them and use them with mounts that are higher up so I don't have to worry about clearing my mufflers or, more importantly, them scraping the ground and sending me into a spin.
And you are a disgruntled seller to a degree, which is fine. Fact is you were all down with making some mounts that raised the pegs up and then all the sudden you weren't. You're not obligated to do it. I just thought it was weird that initially you were cool with it and then all the sudden you weren't. But whatever. Lesson learned.
At this point I don't care. I'll make them work. The passenger peg mounts just aren't going to work though.
Man, I offered you a refund on them. I'm not disgruntled towards you.
I've ridden with mine for 5+ years, never dragged a peg, nor have I heard of anyone who has purchased from me, including racers, dragging a peg. If you get that low, you're going to be in the process of crashing far before my peg hits. At that point, you'll be happy my peg saved your bike from more damage. Until that scenario occurs, please do not make claims on the safety of my product, that you do not know as fact.
I'll see if I have some linkage in stock and stick a set on a bike with exhaust for a pic for you tomorrow.
I have been more than courteous towards you in trying to help you, in one way or another. I'd appreciate the same common courtesy.
I was fine and didn't call you out at all until your post. I made claims of fact. You said you could make some mounts higher up to clear the mufflers. You decided you didn't want to do it. Should have just said so in the first place. Like I said, it's fine. I'll make them work. If you have any more issue maybe you should just email or call me.
Yes, I offered you a refund, rather than spending however many hours on a mill building something for free.
I wouldn't have responded to this thread had you not posted that I was just annoyed with the whole deal. I have told you more than once, on more than one thread that I have no issue with you, still don't.
Just don't like being talked negatively about, when I tried to help you (offered to send different levers, then a refund).
With that said, with your exhaust, and the placement of the exhaust cans, you are going to have to make a bracket that raises the pegs several inches. And, when you, or whoever builds it, make sure you use a stiff enough (thick) piece of metal so that they are not flexing when you put weight on them.
Good luck.
Now kith and make up!
Some shots of these with exhaust on the bike. There is ample room to shift gears, the offset allows you to get your toe comfortably under the peg to shift up, as well as plenty of room to hammer on the brakes if need be.
