[quote author=overdraft]oil baffle in lower crankcase. i drilled and tapped where it is riveted into the lower crank so i could clean underneath... put it back with red locktite? will that work in hot oil?[/quote]
Spot on.
[quote author=overdraft]i'm assuming that this bike is gonna rattle like a mofo being a twin so i'm using nyloc nuts everywhere instead of nothing or those split lockwashers. make sense? [/quote]
Not sure there's any harm in it. I stuck with bog standard nuts and lock washers on my 360 though.
[quote author=overdraft]for the bolts that go into the cases i have a stainless socket head fastener kit... never seize? blue locktite? any ideas?[/quote]
Never seize is a good idea.
[quote author=overdraft]is there any words of wisdom around getting the motor into the frame without banging the paint to hell?[/quote]
Wrap the frame in packing foam or similar (even cardboard or news paper can work) and take your time. Having a friend help is a pretty good idea. Also, you can put the motor on its side on the ground and lower the frame down on top of it. That's the option to use if you're doing it by yourself.
[quote author=overdraft]the manual says apply 'liquid gasket' between the case halves and the let it dry before assembly???? i've never done that before... not that i've split cases before... but i've always assembled when it was wet. you guys?[/quote]
I give it between two and five minutes to get tacky and still apply while wet.
[quote author=overdraft]i didn't see any torque specs for the case to case bolts... am i being blind? or if not, what number should i use?[/quote]
Between six and eight ft/lbs.
[quote author=overdraft]should i fog the parts with wd40 or something before i assemble?[/quote] Depends on the parts. That's what I used for my pistons and cylinders, but everything else got motor oil. When I went to fill it before starting, I poured the oil in through the top end (though a valve cover) rather than using the standard oil filling location.[/quote]
