Cb350 suddenly no spark
SONICJK
Reminds me of...me No, I'm sure of it. I hate him
As the title says.
Rebuilt my 350 and it fired right up.
Runnin on both cylinders, I let it run for about 10 minutes and then started fooling with the mixture. All of a sudden the right cylinder cut out. Left was running great so I set the idle and then tried to figure out the right cylinder.
Cut it off and now neither will fire. Neither cylinder is getting spark.
I've got 12v at the points as I should.
12v at the coils.
5.8 ohms resistance across the coils.
What could I possibly be missing?
Any ideas?
so you pulled the plugs and let them rest against metal to make sure of no spark?
i was also going to suggest your float bowls, are they filling up, both of them?
i would check the resistance in your switch to make sure its flowing current as it should, is it turning over still?
oh also veryify your connections, i had all mine connected and was still having problems, so i disconnected and cleaned them all and reconnected and it did it, whatever was the problem
Got it working.
Cut a little off each plug wire and moved the end cap. Seemed to help.
Now it won't go over 1/4 throttle on the right cylinder. Any ideas on that one?
Well it turns out I didn't clean the carbs out well enough after soda blasting.
The carb slide was literally seized in the carb body. Got that out and now it runs like a raped ape up top an like ass below 1/2 throttle.
Oh well it never ends
