SONICJK
Reminds me of...me No, I'm sure of it. I hate him
I split the cases on my 350 and replaced the kick spindle. While doing that I lifted up a little bit on one of the gear sets in the transmission (think 1/4 inch, the gear set nearest the cylinders) and then thought better of it and let it slide back into place.
Now i put the cases back together and without any more assembly, I tried to spin the sprocket and see how the clutch center rod spins. There only seems to be one gear catching, any other shifting just results in what feels like neutral.
There is no oil in it and the oil pump, clutch bucket, stator, etc is all not installed.
My question is this: Do I need to tear the cases apart and check anything in the transmission or should I just assemble and continue? I am not sure if having all of that stuff uninstalled etc will cause this.
Could I have slipped a pin or something in the trans by messing with it such a small amount?
Thanks,
Justin
Thanks,
Justin
