churlburt
Active Member
I'm about to install the cam on my 350 and i have a question about valve timing. I know that the rotor has to be on the LT mark and the cam sprocket needs to be aligned with the gasket surface. This should put the left piston at TDC on it's compression stroke. HOWEVER my question is this: how do you know the left piston is on it's compression stroke or it's exhaust stroke? And if it is on the exhaust stroke, how do you correct that to put it on it's compression stroke?
Additionally, my valves were ground and reseated so they are not even close to being properly adjusted. Should I adjust them on the bench to start with?
