CB350 weak spark & arcing - HELP! (searched)
o2sensorheating
Hey guys,
So i'm driving down the road last weekend and out of nowhere I lose spark. The bike dies on the side of the road. Since then I have not been able to start it again. That evening after getting the bike home I removed the ignition place to find the ignition rotor had a broken tab. I assumed this was the issue and had the piece replaced but nothing had changed. As of now i have both plugs throwing off a weak spark and arcing off whatever they can at the plug side of the plug wire. All other electronics on the bike work correctly.
My setup:
Sparck Moto wiring harness
Two Dyna single 3ohm coils (blue ones)
LowBrow 7mm plug wires with brand new NGK boots
New NGK plugs gapped correctly using di-electric grease in the boots
Replaced the NGK boots
Charlies-Place electronic ignition setup
New ignition switch
Steps taken so far:
- Rechecked the timing
- Inspected advancer with no obvious signs of issues
- Swapped plug wires left to right as well as boots
- Ran two temporary grounds from the negative battery terminal to each coil bracket in case the grounds were weak
- I noticed the liner of the plug wires had begun to crack (even though they are only 6 months old) so i wrapped them end to end in electrical tape and have new wires on the way.
- I sent the entire ignition back to Charlie-Place to be checked out and it has tested fine there.
- all my bullet connectors for the coils and ignition were removed and soldered/insulated instead to insure best possible connection.
Any more ideas I can try out? The bike ran flawlessly for months prior to this.
Thanks!
Coils are not grounded, so that was not the issue. I assume Charlies place removes the condensers too?
3 Ohm coils draw more power than stock 5 ohm coils. Since it looks like all the pieces are good, assuming you checked them correctly, I would ask what is the battery voltage when off, what is it when running. /what is the voltage the coils are receiving? Low voltage from the alternator will cause symptoms like you have....
Having Sonreir's wiring harness, I know the wiring is good. But a loose battery connection or loose connection to the ignition switch can all cause voltage drops.
Hey mydlyfkryzis,
Thanks for the reply!
I forgot to mention i have a new reg/rectifier with a hotshots upgraded stator. I will recheck the connections at the ignition switch as well as off the battery when i get home today. My repairs and testing since it broke down i had the battery (a 4-cell antigravity battery) on its charger. I guess its time to whip out the multimeter. Out of curiousity, what setting do i want to be on when checking the connections?
You should be checking for voltage. You may need to do this a bit at a time, as leaving the ignition switch and kill switch on without the bike running is not good for the health of the coils. They'll overheat and cook after a few minutes, especially the three Ohm variety.
At the front of the harness, there will be two black wires, each with a triple female connector on them. The thicker of the two is the one used for the headlight and coil circuit. Ensure the kill switch is plugged into thicker black wire and that the black wire has 12V on it. Next, with the kill switch set to run, check to make sure you have voltage on the black/white wire coming from the kill switch. After that, check for voltage again on the white wire to which the ignition coils are plugged in. 12V here, too. Then check for 12V again on each of the points, where the yellow and blue wires connector. You can turn the bike off now and then check for resistance between the yellow and ground, and blue and ground when each sides' respective contact point is closed.
Ok so I pulled out the multimeter and had 13v at all the above test points (the battery was on a charger but was off during testing). I also checked the resistance from the engine case to the negative terminal just to be safe and it read between .4-.6 (ignition off) and 1.1 (ignition on)
UPDATE - I decided to try and run a jumper cable from the spark plug threads directly to the neg terminal to see if I'd get spark back. It worked flawlessly on both terminals. What does this mean??
And if you hold the spark plugs against the engine cases while trying to start the bike, you don't get spark?
The engine grounds to the frame through almost all of the mounting points. It's possible, but unlikely, that the engine would be ungrounded. If you had the frame powdercoated, I recommend filing off the coating at one or more of the mounts.
Understood, I will double check the mounting points tonight for the engine. New plug wires should be arriving today but i did cut and clean my existing plug wires with no success. Assuming its not the plug wires, anything i could be checking?
New plug wires built and installed. Strong spark against the case, weak/arcing spark away from case. Thoughts?
The spark plug needs grounding. When you move the plug off the case,, it has to jump the gap at the electrode and the gap at the plug base to ground....
If the spark is good at the electrode and the plug grounded, then it is good...
I probably knew that, haha. Ok, so tonight I will re-check the timing on the bike. Still seems strange as the timing shouldnt have shifted since it ran.
