cb350 Wiring-Front Brake Stop Switch??
Bobdot
Coast to Coast
So I noticed my brake light does not get brighter when I depress the rear brake with the headlights on. The brake light works fine with the headlights off, but nothing changes when the lights are on. Going through the wiring diagram I found a few F-ups by the PO which I was able to fix but one last connection still has me scratching my head.
I have two open wires in the headlight housing that are supposed to lead to a "Brake Stop Switch (Front)." Alas, I have no switch of anykind to connect them to and I'm having trouble finding this "switch" on the web. Anyone? Can/should I just make a solid connection between the two wires (Green/Yellow and Black)?
Here's the diagram:
The switch in question:
bob.
If you make a connection between those two wires the brake light lights up. The switch is located in the right brake perch. Bikebandit.com offers this switch the last time I looked. I need to replace mine as well. I just have the two wires hanging in the breeze at the moment.
Josh
I'm going to pick one of those up too. I'm still working on how to add a drum brake light switch to my XS650 project. I might be able to retrofit one of these switches to my aftermarket levers if I can get the hole drilled right.
Your Honda dealer should be able to order one for you or check at www.servicehonda.com
You can buy those from your honda dealer for $7--or 17, I forget. From momory, it uses a switched ground to light the light. I wired mine as a switched live and it's been fine so far.
May sure your foot brake isn't activating the light, and giving you a false negative.
--Chris
Did you ever end up drilling that hole? I have aftermarket perches for my cb350 and need to drill a hole in mine. I have the switch cable, but im confused as to what the cable actually plugs into inside the hole... mind elaborating? thanks
Sirius Consolidated Inc. sells a set of levers with the hole for the brake switch already there, pretty cheap too.
http://www.siriusconinc.com/pro-detail.php?pid=&product_id=3976
