TheProspector
Active Member
Thankfully, no issue with the valve cover. The tappet locknuts were seized on, so I let them soak in penetrating oil for a day and just had to use more force. It's easy to get timid when trying not to damage/strip/break these old fasteners.
Was able to apply the bonding gasket and install the head cover.
It's nice having a Honda shop close by. It's much cheaper (most of the time) than sourcing things online, esp if you keep needing to pickup small things. I had to get a replacement ball for the clutch rod/lever assembly as well as a locator dowel and not having to pay shipping for these small orders is great. They also helped me locate the felt wiper for the points plate from a shop in PA, since mine was toast. That shop (Scott Powersports 610-282-4800)apparently has 5 more in stock if anyone else needs one... Was $6 shipped.
My bike didn't come with any stock air filters or covers, so I bought velocity stacks years ago without knowing the struggle others have had with jetting their carbs... I am going to be getting some UNI air filter foam to cut to size for the inside, and my new mufflers seem to be almost as long as OEM, so I'm hoping it's not going to fight me too much. Also am trying to visualize and prepare for the battery being in the way and coming up with a diff solution... Just was too hard not to see what they'd look like though. Unsure about keeping them or what I'm going to do in the end, but here's how they look.
Also, now you can clearly see how yellowed the starter's clear coat is compared to the rest of the engine. So, since it's easily accessible now, I'll be repainting it.
Oh, I bought an OEM seat that has a good pan and looks like good foam. I thought I may have kept my original seat, but I must've tossed it at some point because I couldn't find it in the barn. :-\ So, I'll be recovering this seat since the cover is quite cracked. Hoping the foam isn't too crusty.
