Cb360 Cam, cam chain, and atdc, and LT mark
  • Thread starter Thread starter boulevard
  • Start date Start date
B
boulevard
Guest
I am putting the top end back together on my cb360. I have the crank shaft set to the. L.T. Mark, the cam chain sprocket is set to the where the lines are horizontal with the top of the engine. The left cylinder cam is down.
THE PROBLEM
when I put the head back on and try to turn the engine I can see only get a half turn before it sticks and won't turn anymore. It is as if the cams are not aligned right. I have read the manual and had friends read it. No one over here can figure it out.
It has no problem turning with the head off. Only when the cover goes on.
Please help I am so frustrated that I can't figure this out.
Boulevard
There is no LT mark. It's either 'L' or 'T'. All valves need to be closed at 'T'.
Lots of hondas have the 'ability' to rotate the cam 180 degrees and that's usually the case.
There is no such thing as 'the left cilinder cam'. All lobes need to be down at 'T'. 'T' is for Timing, and thats the point you want a spark and all valves to be closed.
I appreciate the response. I promise I have an LT mark but none the less I am willing to try something else.
More info... When I am on LT the left cylinder is at its highest point. I read the manual to say that when the left cylinder is A.T.D. C. 90degrees after LT mark then set the sprocket to where lines are horizontal aligned with the top of the engine. Then screen the sprocket back in to the cam. I did that and also tried it 180 degrees the other way which would also be horizontal. When I do this the lobes above the left cylinder are down but the right ones are up.
If I understand you correctly this is what I am going to try. Set the crank to T and then set all the lobes down the attach the sprocket to lock everything in to place. All lobes down at the T mark.
Boulevard
CB360 has LT, LF and F, T marks.
i'm sorry, i was wrong. Had been typing all sorts of posts about cb200 camshafts and got them mixed up or sum.. Sorry, can not help you, have no exp with 360's.
Here's some pictures of my CB360 properly timed after a motor rebuild. I can tell you it ran after being assembled like this, so I must have done something right :)
http://www.dotheton.com/forum/index.php?topic=44198.msg496010#msg496010
Awesome that helps. That is the way I had mine set up too. I figure out by accident that the reason it was locking was due to the chain tensioner. One of the times I put the head back on I accidentally forgot the tensioner and it turned over no prob.... I freaked out and thought what was different this time... Saw the tensioner on the ground. Aha! So I out tensioner back in and then loosened them at the bottom of the engine and walla the engine turned over.
I was getting really tired of putting it together and taking it apart. Then looking at manual. Then putting it together and taking it apart.
Thanks for the photos that Confirms for me that I got it right.
Boulevard
[quote author=Bert Jan]There is no LT mark. It's either 'L' or 'T'. All valves need to be closed at 'T'. Lots of hondas have the 'ability' to rotate the cam 180 degrees and that's usually the case.[/quote]
All valves (on the left cylinder) will be closed at T only half of the time and ALL engines have the ability to insert a single cam 180° out without causing any problems at all.
[quote author=Bert Jan]All lobes need to be down at 'T'. 'T' is for Timing, and thats the point you want a spark and all valves to be closed.[/quote]
Again, this is only true for every other rotation. Half of the time, aligning the crank to 'T' will have the valves open.
If you're setting the valve clearances, the important thing is just to make sure the valves for the current side are closed. Honda says to use 90° ATDC because that's the point (in every other rotation) when all four valves are closed.
Boulevard
Cool, glad that helped. What I did was time the motor with the rocker arm cover off, then "dry" (no sealant) installed the rocker cover with all the rocker arm adjusters backed all the way "loose." I slowly turned over the motor to confirm timing, then removed the cover, cleaned it and installed sealant, and installed it for good.
I am so glad you responded. Please tell me what 90degrees atdc means.
1. Does that mean to place the index mark 90degrees from the LT mark (which is atdc) . If that is the case there is no mark at 90degrees. Am I supposed to eyeball it
2. Is it saying that "LT" and 90degrees A.T.D.C are the same thing.
Boulevard
90° ATDC is 90 degrees After Top Dead Center.
LT is the top dead center mark on a 360 engine, and so 90° ATDC is just another quarter turn past that. There is no mark for 90° ATDC.
