cb360 chem-dip carb dunk
keeleydavis
I just opened up the carbs on this 75 cb360 and they are totally filthy. After removing the gasket and o ring for the pilot screw, am i okay to dunk the whole carb in Berryman chem-dip? Is there anything I am forgetting that may be plastic or rubber? Much thanks
Yeah remove the float bowl and its gasket, remove the top cover and most importantly the diaphragm and slide
It will probably screw up the throttle shaft seals, they are felt and need some oil on them
I HATE chemical carb dips for CV carbs, always screws up something
Are there replacements for those PJ?
Noticed them when I broke my carbs down, most if not all are still in place but I've ordered genuine Honda oring kits and there are a tonne of different ones in there, wondering if any where orings for replacing the felts.
I've never seen any, but, I haven't looked too hard
Honda doesn't supply them except with a new carb body
I was thinking of searching in craft supplies for thick felt and getting or making some hole punches
I don't know if 'O' rings will work without causing excess drag or sticking?
Later carbs (80's on Mikuni) use nylon (Teflon?) 'seals'
Hey, did you end up dunking those CB360 carbs in Chem-Dip? I'm breaking mine down right now and would really like to chem dip the carb bodies to clean them up. Crazypj, you mentioned the throttle shaft seals? Where are the located on the carb? Can I get them out and reuse them after I Chem-Dip it? Thanks for any information.
Throttle shaft seals are on the throttle shafts,you have to remove throttle plates and choke plates then remove the shafts
They don't come out without breaking as they are pretty brittle after 30+ yrs.
