CB360 forks - looking to make them 1" longer - what are my options?
Cursh
Loves Stock Airboxes
So . . . I got clip ons and was worried about installing them below the upper fork trees because . . . that feels really low, and I'm not really that bad ass (Like, I like my riding position) so I lowered the front end enough to clamp the clip ons above the fork trees. I dropped the back as far as the factory shocks would go (about an inch) and the bike handles alright, but the fender was getting dangerously close to the scrambler exhaust (in fact - with the original fender it was hitting it under hard deceleration . . . terrifying - shut that down immediately) So, anyway - its a little twitch, but not terrible, point is - i'm much more interested in having a bike that handles well than having a bike that looks right - so I'm looking to bringing the geometry back to normal, and will need to extend the forks an extra inch or so. I can hog out some material to get the clip ons closer to flush with the top of the fork trees
So what are my options to have 1" longer forks?
So far I've thought of buying other 33mm forks off of ebay (XS400 is one I've found) and seeing if they are longer - and maybe swapping in the tubes, but at this point it looks like I'd just be buying used parts and guessing (which sucks)
is there an easier way?
-Thanks-
Ben.
Probably the easiest, but not the most cost effective way to get around this is buy a set of clip-ons with a bit of rise to them.
Woodcraft makes them with 1-3 inch rise in 1/2 inch steps. I'm not sure what the CB360's fork diameter is and they might not make something which fits... Here's the link:
https://www.woodcraft-cfm.com/cgi-bin/commerce.cgi?search=action&category=CORI
Those only come in 36+ mm sizes. Dime city cycles can has a couple options which might work.
70mm rise:
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-handlebar-parts-33mm-high-rise-tarozzi-clip-on-clipons-56-0014.html
40mm rise:
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-handlebar-parts-33mm-low-rise-tarozzi-clip-on-clipons-55-0014.html
I appreciate pointing me to the clip-ons. I think Id be more likely to spend the $40 on some 33mm forks and try to put a few different things together. At least at the end of that $40 I will have learned something.
That is a good option though, and one that I may land on when the XS400 forks end up being less viable than I wanted them to be.
Is there a good way to load the springs to give myself an extra inch of lift (similar to putting spacers on a trucks springs to lift it an inch or two?)
-Ben.
superbike bend handlebars are the answer
clip ons are for racing or for posers they arent really suitable for street riding anyway
you cant just jack up the springs
Thanks, but I had those bars, and while they looked great, I felt absolutely stupid riding around on the bike. Its a little bike, and I'm a big guy. it was like sitting in an easy chair. Flat bars were still too close to me, so now I'm in a spot where I like the bar position, but the suspension needs to be sorted out.
If I can't "just jack up the springs" then I guess i'll start tearing apart 33mm forks and see what comes of it.
Thanks.
I suppose you could always replace the fork tubes with something longer and add a PVC spacer to match the new length. A tube from a dirt bike should be longer. Check the parts diagram to see if that makes sense. In all honesty I think it would end up being cheaper, easier, and take less time to buy the proper handlebars.
List of fork tube diameters:
http://scandalon.com/2009/06/motorcycle-fork-diameter-chart/
CB360 front fork schematic:
http://www.cmsnl.com/honda-cb360-1974-usa_model1007/partslist/F++07.html
How to on PVC fork spacers:
http://faq.ninja250.org/wiki/Where_can_I_get_some_preload_spacers%3F
thanks so much for the links. It looks like you are right, but pouring over that info was very helpful.
How much static sag is there in the stock forks? Stock OEM springs do tend to get soft and typically have way too much sag. Check that and it it's too much, fit stronger springs. That will lift the front end a little.
Then I'd fit a set of Drag Bars to get more or less the same bar height but with the forks pushed back down where they belong.
That may be enough to restore handling and get the riding position you want.
Thanks - Forks are due for a rebuild, so I'll add springs to the list of parts for that project. I picked up a smaller stock fender (going for a sort of OEM+ look here) and am planning on grinding out a bit of meat on the upper triple to allow the bars to sit a little lower. Honestly I love the feel of the bars and didn't have the same position from low super bars. IF springs don't make the ride level, i'll give drag bars a shot.
