Tonnotyetdone
Trying to eradicate the gremlins from my CB360. Currently, the right front blinker does not work. Running lights work on both sides, and both rear blinkers and left front turn signal work as well. Tried a couple of bulbs in the right turn signal assembly to rule out one of the dual filaments being busted, but no luck. Tried testing for power going to the blinker, but had no luck getting connection. I was using a continuity tester grounded to the engine...worked for the running lights, but I couldn't get a light with either turn signal. Should I be grounding it at the stem? All connections seem to be intact and the turn signal flasher has been replaced. Wiring diagrams have been of little help thus far. Any ideas or help regarding the matter would be greatly appreciated!
Sent from my XT1565 using DO THE TON mobile app
