cb360 general question
niko
hi I have a non running cb360, I'm getting 150psi on each cylinder ( haven't checked valves, haven't done oil test yet) and this is on cold engine. it's about 10° outside. what do you guys think?
when it's warm and running any guesses at what compression should read? I've been told to aim for 170psi... without doing the other tests do you think I should do a top end rebuild or will I be getting most out of the mochine as it is now
Re: cb360 general quotation
sorry I meant should I be planning on doing a top end rebuild, I'm not asking if I should just dive in and start rebuilding before doing more tests... I'm just looking for your thoughts options and guesses
165 is the minimum on a warm engine. 150 sounds right for a cold one.
I'd leave it alone. Just check the valve clearances and chain tension. Leave the head in place and everything put together.
