So I just picked up a running Cb360. The headlight and tail light both work as they should (high beam, low beam up front, running and brake in the rear). All turn signals flash as the should however my front left signal light stays lit like a running light when the ignition is on. I don't know if the signal lights should be lit like running lights when not flashing or if the light that is on should not be. So I peer into the fuse box and find that the fuse marked "TAIL" is blown (tail light works fine though). I turn the ign. off and replace the fuse and turn back on and it blows again. I am hoping that someone can point me in the right direction. All suggestions are welcome. I hate electrical stuff!
