pj take a look at this . im thinking i put the kicker spindle upside down, or 180 degrees out. pulled the clutch cover and saw it hitting. i would assume the notch on the spindle is supposed to go underneath the notch inside of the case , the notch holding the spring
it would seem that where i have the kicker spindle notch [resently, it is only allowed to travel to the spot where the sping is held on. would also explain why it doesnt have much spring to it.
yep. 90+ 'out' the stop needs to be behind the stop on case.
Fit kickstart temporary so you can 'wind up' the spring
Did you remove circlip and spring?
