Hi, I've seen lots of posts on cb360 swing arm bushings but never seen a swing arm like mine....
I assume the bushings at the rear can be pushed out using the threaded rod and washer trick used by many...
But what about the bushings at the front where the arm joins the frame have you seen anything like this before, is there anything I need to remove here before powder coating or anything I should consider replacing?
Thanks
Matt
Thanks
Matt
