cb360 no spark
hanten
I've got a 74 cb360 with no spark. Rebuilt the motor last year got it running till it would warm up then die. Put new points in it because they were pretty much shelled and then lost spark. Put new ones in again yesterday thing ran like a top rode around for a good thirty minutes parked it came back to it today and had no spark in either cylinder. Have power to the coils. My hues is condensers but not 100% sure. Any tips ideas are greatly appreciated. Thanks in advance
are the plugs new?
check the gap, check the plug wire cap.
On one of my 360's it ended up being the wires coming from the stator to the coils, there was a short and once replaced, spark was great.
My 360 coils were on the fritz, got some xs650 coils and a "tune up kit" of eBay that came with plugs, points and condenser and I haven't had a issue with spark since. The old ones were overheating after riding for a while.
Yeah, I'd look at condensors and coils. Can't remember what the test procedure is off hand but I'd put money on it that crazypj does.
maybe flakey coils. once they heat up they can open up. then once cool make back up again.
What all can I update as far as ignition goes on this? I was reading something about new coils earlier on here and can find what they were now. Do they make anything to replace the points? I'm almost positive the conderser is what is bad find out when get one ordered.
Dyna or similar coils
Pamco ignition will replace points and condensers.
Hondaman (great value for the $69) will replace the condensers and it uses the points basically as on off switches.
I believe Pamco sells a kit with new coils and electronic ignition for a bit over $200. I've used the hondaman and the Pamco and like both.
Hey thanks boss. 115$ to my door. I think ill get the 14$ special for coils although the site says this system is compatible with the original coils. So I'm lookin at 180 to my door. Good bye headaches.
Any update on this? My 360 now has no spark and there was some smoke coming out from underneath the gas tank. Wiring is fine. I am thinking it is my coils heating up. Going to test it out tomorrow. >:(
