cb360 rebuilt starter issue
sinjinle
Ok Gang,
Need a little help here. when i first got the engine back to together. She started fine with the electric start and it only took on kick to start her up with the kickstar. Now when i tried to start her up with a kickstart, it seem like it's harder to push down and it sprung back up pretty hard. and when i tried the electric start, there's a loud clicking sound right behind the points and then a puff of smoke came out of the air filter. it does it once in a while. could this be something of a timing issue? it almost sound like the piston is hitting a valve? any help would be greatly appreciated. The video i posted is when i first started her up with no issue.
cb360 engine rebulit first start
You did clean oil pick up?
(there is oil in it? I had to ask ;))
Sounds like there is a click in there when you first started it, have you re-checked valve adjustment and for exhaust gasket leaking at head?
sinjinle said:
Ok Gang,
if that's the first time you started it after a rebuild, honing and new rings, you really shouldn't let it idle like that at first, you want to build up oil pressure asap so the rings don't dig into the cylinders.
I had this EXACT same problem with my 75 cb360. Clicking sound and smoke from the carbs and also the kickstarter springing back pretty hard.
First, the issue with the starter is most likely a slipping starter clutch. I ordered a used one off of ebay for about $40. I then went to remove the original one, but lacked an impact gun and in the process messed up the timing by turning the motor in the wrong direction. Then the bike wouldn't run at all. I adjusted the points and timing and it fired right back up (with kickstarter) and it has run great for 3 months now. So I'm guessing that you may have the beginnings of a slipping starter clutch.
Second, the issue with the kickstart. My kickstart sprung back so hard one time that it put a hole into the crankcase cover. I pulled the cover off to find it had broken some metal off that the return spring rests on. I posted the problem here on the forum and no one had ever encountered that sort of problem before. Anyways, I cleaned out the metal and adjusted the kickstart so that it stopped on its return at the correct position. But besides it springing TOO far forward into the crankcase, fellow dothetoners have told me that it's perfectly normal for it to spring back hard and be hard to push down... that means you have good compression.
I'm going to guess that since you rebuilt the motor it has much better compression now. I bet your starter clutch was already worn but now that you have much better compression the clutch can't handle it. Same goes for the kickstart... it feels harder now because it is due to much better compression.
Hopefully that helps.
Thanks for the info! when i rebuilt the engine. I DID replace the starter clutch as the old one was so mess up that melted into the crank shaft (replaced that too.) . I am at a stand still. any mechanic in the Northern Cali area?
