cb360 running problems
CB360ty
Active Member
I just got my bike running after storeing it last fall. It didn't take long to get it started and it seems to idle fine but once I took it out it would back fire when I let off the throttle and the right exhaust seems to get hotter then the right. I checked the spark plugs and they looked the same and I also took my air filters off and tried covering each carb to see what happens and when I covered the left carb nothing really happened but when I covered the right carb it shut off almost right away.
I am not sure what else to check to figure out what's wrong. Any ideas on what could be wrong would be helpful.
It's strange that the plugs look the same but the left cylinder is a problem. I'm guessing the right side is burning the gas efficiently (good spark, proper fuel flow) and the left might not be burning at all.
Check the left carb - I'd bet it's not getting / delivering fuel. Did you use fresh gas before starting it or put Sta-bil in the tank before storing it?
definitely a left carb issue. i say take off the float bowls and check if everything is clear. if it hasnt been done before, a carb rebuild should be done.
Well the problem is fixed and it runs perfect.
I learned 2 things in the process:
1. I am an idiot.
2. It turns out not having the exhaust on properly can cause all the problems I listed.
I had recently taken my exhaust off to paint flat black and I must have put it on wrong over winter. I reinstalled the exhaust the right way and the bike runs perfect.
Thanks to all that tried to help, I appreciate it.
By the way, here is how she is looking now.
Glad to hear it worked out for you! I would have never guessed checking the exhaust......
Be grateful that it took you this long to find that out, I knew from an early age I'm an idiot! :D
yeah exhaust leaks can do wonders. your lucky you caught that one... you could have had spent a SERIOUSLY long time trying to troubleshoot ;)
