CB360 Stumbling Missing Hestitating only when warm
Griffs
Hey Guys,
I have a 1975 Honda Cb360 that I have been restoring for the past few months and attempting to do things right. However after a full tune up and carb service the bike misses/hesitates/lurches while cruising only when hot (5+ miles into a ride.) Cold, the bike runs great & starts first kick. Bike hates the choke, doesn't like to run on it for more than 3 seconds. Bike has the stock ignition system / points / condenser. Battery 13+ volts and getting that voltage at the points.
CrazyPJ Carb Service for Pods
New Diaphragms
K&N Pods
Factory Exhaust with a few rust holes towards the end of the mufflers
Every single electrical connection cleaned and dielectric greased
New Kohler Regulator/Rectifier
7AH Battery
Cam Chain Adjusted
Tappets Adjusted
NGK Plugs Gapped
Points Gapped
Timing Spot on
Any Ideas?
Test your coils after you take it out for a ride, could be that one of them is going south.
I tried the continuity test across the black/white and ground as well as yellow (blue) wire and ground and got nothing. I read that sometimes when the coils get hot they start flaking out.
define "cruising" what gear, rpm, speed? if its 55-65mph in 6th...your probably running a bit rich. try some plug chops.
25-35-40 mph ranges accelerating smoothly through the gears not beating on it. I don't remember the gear I am in but it was probably around 3-5K rpm when it breaks up. If you are in the problem range and just go WOT it pulls strongly and doesn't hesitate. Checked both plugs after the last ride and they both looked perfect.
Although I accuse PJ of overly meticulous work on a regular basis ( he does obsess )
this is a good thing . However one of the things he can not account for is post installation float height . Get in there and verify that first the float height and the fuel level are within reason . If all is well with the fuel level find a coil or coils to swap in as under load testing of a suspected coil is a pain . Also I have seen condensers fail under load and heat when they were fine cold . Nothing too terrible here just track it down and get r done .
~kop
I am going to adjust the idle screws and check the float height this weekend.
I don't have any parts to swap and test so, I have new plugs, caps, wires, coils, condenser, and points lead coming on monday.
Thanks for the help guys.
get her to stumble and keep her there, stumbling for 15-30 seconds or so. then immediately do a chop and see what your plugs look like. Rich main primary? mid range. 4-5000 rpm. the reason it smooths out when you go wot is your dumping a whole bunch of air in there. Once youve passed the rich point by adding air and the needle starts to rise. if you have a lean main secondary or needle (they compensate for each other) so maybe do another chop @ 7500 + rpm. and see what you got. you need to cure that rich problem first. making sure NOT to go too lean anywhere else in the entire range. rich wont really do any damage but lean can burn valves, etc
