CB450 first start... insanity ensues
pbussey
Stifled...
ok, so I got everything back together necessary to getting the 450 to run.
1. carbs rebuilt and cleaned
2. points cleaned and gapped
3. coil grounds and connections cleaned
4. timing set (supposedly)
5. plugs have fire
6. starting fluid (for testing)
So I am trying to fire old Brownie up, and well things are getting quite frustrating. I spent the better part of a day getting the timing and points straight, and they seem to be staying there. During cranking, I will get random puffs of ignition out the left side tailpipe and both carburetors. I get a noisy chain slackening sound during these puffs, but I assume that is the starter chain doing its thing when it fires over. There is fuel in the float bowls and it seems like everything *should* be working, but isn't.
Any Ideas???
Thanks,
Parker
Is your battery fully charged? Check for good voltage coming off your battery or you won't have enough spark...
I can try switching the coils, but the wiring colors match up in the harness. I'll post an update to this try tomorrow.
The bike is being powered by a roll-around battery charger-starter, so it has plenty of juice for the spark. I tested the plugs with a gap of .100" and it still fired strong
The tank has been cleaned, acid dipped, acid etched, and POR-15'ed. It should be fine, plus there is clean fuel getting into the float bowls.
OK, update. I swapped the coil trigger wires and it works a bit better. It will fire up and "run"/rev for about 3 seconds, but then dies. It seems like it isn't getting any fuel after the initial start and then just dies...puzzling. Everything is for sure clean in the carbs; floats adjusted well, jets all clean. So could there be something amiss with the idle mixture?
did you take off the points cam? If so, did you put it back on the correct way? i think on those bikes you can put it back on 180' out of phase without really knowing it
Well, I figured out that when the coils were swapped around, the intake cam jumped a couple of teeth. I still have compression, but that can all change once the cams are back in phase with each other :-[
