CB450 oil leak from clutch cover
joevirus563
Coast to Coast
I have a big oil leak from the left clutch cover. New gasket are installed in all the engine.
BUT! I found 2 things:
1- The pushrod seal got damaged a tiny bit on the outside. Could a lot of oil slip trough almost a non existent hole? Is that a big oil pressure area?
2- The connector from the alaternator wasn't seated at all in the hole at all. NOT LIKE THE PICTURE. Could it be that?
Could a good quantity of oil escape the cable hole if no cable is in?
images
Probably the alternator wiring. My 450 was leaking from there till I added some RTV around the seal.
CC
