CB450 valve adjustment
bobjohnson
Coast to Coast
Sorry for another post, but im stuck. Trying to adjust the valves on my cb450 and it seems no matter what i do, i cant take out the slack. Ive had the cam in multiple positions, looked at both my manuals and i still cant figure it out. If i turn the adjustment knobs, the feeler gauge gets stuck, then i back it off a bit and it feels snug, but if i try the next size up it slides in no problem ???
The only thing i noticed was that the adjustment knob mark points inward. The manual alludes to the fact they should point away from the middle of the engine, and reading up online says the same thing. However, i dont know which way i should be turning them since either way doesnt seem to be tightening up the clearance.
I think the main problem here is that i have absolutely no idea how the torsion bar system works. When i turn the adjustment knob i can see the tappet moving, but it moves in and out, not up and down... The clymers manuals i have are completely useless (the first one had the wrong clearances which really wasnt helping at all).
Maybe i should have just bought a SOHC ;D
Ok after 7 hours i finally got it. Apparently with the torsion bar adjustment, you can get the clearances correct with the index mark either pointing in or out. However, with the index mark pointing in, its wrong (no idea why, i just read it online). All of the index marks were originally pointing in (i think this is why the valves sounded so bad when i was running it the other day), so i turned them clockwise until the index marks faced out.
The other problem i had was the stupid clymers manual instructions for setting TDC on the compression stroke are wrong. Or maybe ive got an after market rotor and the marks are off. Im leaning towards the clymer manual being wrong because the clearance it calls for are definately wrong (0.003" or 0.02mm, those are 2 completely different measurements), so i went with what i found online (0.04mm).
Eventually what i did was just set each valve individualy, didnt worry about setting the engine to TDC, i just put the cam lobe at its highest position and rotated it as i finished each tappet. I figured the tappet isnt going to move if its on a torsion bar, only when the cam comes around and applys pressure to it. It worked ok. I started the bike up and it seemed to run fine, i didnt run it long but no weird noises, no smashing valves into pistons (i rolled it over by hand about 15 times first so i was pretty sure that wasnt gonna happen anyway).
Next struggle? Tuning the carbs by ear. I can do it but goddamn do i hate it ever since i made my homemade vacuum gauge. Whos bright idea was it to not include vacuum ports on the 450??
