CB500/XT550 "Americano"
Jamoni
Active Member
SO, I had to sell my last project before completion. I ran out of space in the shed and had to make some.
I have a NEW shed, more like a barn, so I have plenty of room. :)
So now I have a new project:
I scored a CB500T frame and swingarm, titled, off of craigslist for $50.
I scored a Kawasaki 454LTD complete from a buddy who needed it off his porch.
I had played with the idea of shoving the 454 engine in the CB frame, but it's about 4 inches too long. So I plan on using a big bore 2 stroke thumper from a dirtbike.
I removed the front end and rear swingarm, and bolted both up the the CB.
I had to modify the bearing races to fit the CB frame. One had to be set into a spacer ring since it was too small, the other needed about 1/100" shaved off the OD to press fit. I also had to make some thin spacers to center the new swingarm, as it had about 3/16" play side to side. Other than that, everything bolted right up.
Right now it's got the 454 shocks on, but those are too short. Also, I'll need to do some mods to the left shock mount on the frame. The 454 swingarm is much wider on the left, to clear the belt drive, so the left shock is about 1 1/4" too far to the left. I'll probably fab an extension to the existing mount that screws on, then weld it for good measure.
Once I get the engine in, I'll be able to figure out the stance, buy the right shocks, and adjust the forks correctly. Everything is WAY too low now.
The belt drive will be going away, to be replaced with an EX500 hub carrier and sprocket setup. I'd like to keep it, but the frame of the CB won't allow it. Oh well.
Handlebars will be clubmans. I'm going to fab up a minimalist seat pan and rear hump out of aluminum diamond plate. the taillights will be built into the hump. Front "fairing" will be the same way. Going to have a buddy weld up a skinny loaf of bread tank out of the same stuff.
Whatever happens, it'll be a learning experience and a lot of fun. Stay tuned.
Re: CB500T Frankenbike
Looks like a good start to a promising build! I've been wanting to convert an old dirt bike with a big two stroke single for a while now. I'll be watching this one for sure.
Do you have a motor lined up yet?
I'm trying to line up a TT600 motor, but wouldn't turn my nose up at a DT400. I'd probably be okay with an SR500 or Suzuki Savage 650, too. Any suggestions on decent mills? Are there any reliable 2 stroke air cooleds out there bigger than the DT400?
I'm calling the local bike scrapper tomorrow, and will offer to trade the remains of the 454 for a motor and hopefully the parts to convert to chain drive.
Maybe a 660 out of a Yammy Tenere? What about an "F" series BMW engine? Depends also if you're dead set on an air cooled or not too though. There's some monster singles and twins out there bro. Jam the biggest one you can find in that sucker!!
We have a motor!
XT550 with a screwed up rear wheel, wiring harness, and all sorts of other junk. Not worth fixing, but the motor has potential. :)
Will be parting this bike out if anyone needs something from it. Clear title.
EDIT: BTW, those are brand new Avon Distanzias, with maybe 400 miles on them.
I didn't have much time this weekend, due to issues involving pretty girls.
HOWEVER, I DID manage to pull the engine and test fit it in the new frame:
I'd call that a pretty good fit!
My messy shop:
As a bonus, one of the rear holes matches almost perfectly with an existing motor mount on the frame:
That'll be a big help in mounting everything square.
Next step is to fab up the motor mounts!
Not sure if anybody cares, but I got some handlebars and controls on it, and started work on the motor mounts. Today's project is getting the motor mounts complete and the motor mounted. Then I can start moving electronics and other parts over from the XT550, and ifgure out locations for those.
Pics later, maybe.
Also, my girl decided that "Americano" would be a good name for this beast, so there you go.
This build may have just veered off in another direction:
That's a mock up using all the crap off the XT550. Due to work issues, I'm going forward on a budget of $0, so reusing as much as possible is now a priority.
The tank and seat should mount easily, I'll cut back the fender and fab a bracket for it. The lights will go on a plate at the rear of the seat, and the license plate will mount bobber style down by the shocks. Still want to get 14" shocks for it.
Also, does anyone have experience cutting down front suspensions? That thing is like a mile long. I don't mind a little sticking up over the trees, but that's ridiculous.
EDIT: I got the templates for the motor mounts mostly done, just need to position and drill a couple holes. I'll need to drill three holes in the frame, insert tubing, and have welded in place. I don't trust my welding on sheet steel. Once the templates are squared away and everything lines up, I'll fab up the real ones out of 3/8" aluminum plate. Then it's just a matter of getting the spacers right and the engine centered.
Yeah. I was hoping I could get it to work out since I really want to use that wheel. But they are pretty hideous.
I guess I'll try to source a stock CB front end somewhere, and get it to work with that wheel.
