Heh...just about anything will be better than the 30+ year old boingers on there now.
You cna spend hugh $$ on Haggons or Progressives, never mind getting into some of the 'High end' stuff. Go to Omar's and spend $100 on some good basic rear shocks:
http://omarsdtr.com/shox3.html
... or if you want something really spiff, go $150 and get the cool old hammer heads!
http://omarsdtr.com/shox2.html
For up front, you have a couple different avenues to think on:
1) Rebuild the stockers $
-New seals and fluid
-add a spacer to the damper rod for a 1" drop
2) Rebuild the stockers $$$
-same as above plus
-Aftermarket springs
-YSS or Racetech cartridge emulators
(requires a little hand drill work on the damper rod, adjust fluid viscosity and level to suit)
3) Swap $$-$$$$$$$$
-75/76 Goldwing forks will slide right into the stock triples on our bikes and they have a far superior caliper mount as wel las allowing dual discs and spoked wheels. You can then all but bolt on CB1100F dual pot calipers with some EBC or Galfer pads and stand that little beastie on it's nose. I've seen complete goldwing front ends with a good rim etc go for $50 locally. You'd still want to rebuild and possibly add the good innards but you're still going to be way ahead of the stockers without changing your triples.
-I've got a set of 41mm Showas with triples and OEM brace from a BMW K95. They are substantially stiffer and lighter than the stockers with a much better axle indexing system. I picked them up for cheap at a local bike event. In my case I'll swap the stem from my 500T over to the BMW triples and run some tapered bearings. I was able to score new progressive springs and YSS cartridge emulators for under $200 total. It all comes down to searching.
Speaking of bearings and suck, you have probably already checked.replaced them but it's worth looking at your swingarm bushings and stem bearings and replacing them with new ones if they're shot. That'll help a lot too.
You should consider rear sets, nothing too radical but it'll make those low bars nicer on your back and you'll be one of the cool kids!
