CB550 electrical problem
Nosepick
1974 CB550
Wondering where to start with this electrical problem…
There is something funky with the lights on my 74 CB550. Right now the blinkers only blink when the headlight switch is off. When the headlight is on all the lights are on and the blinkers won’t actually blink…
I’m not very mechanical and even less ‘electrical’…. Sooo I have no clue where to start. I’m thinking relay switch?
Any thoughts?
Sounds like someone wired your blinkers as running lights... incorrectly.
I would try and find a wire from your headlight or headlight switch that is running to your blinkers... and remove it to see what happens.
Of course it could also be a short. But would be in the same area.
(reason for this assumption is that they're getting constant power when the light is on, normal when it's off)
Hey thanks a lot for your insight... i'll give it a go.
I have an electrical schematic of the bike so I’ll try and decipher it.
Cheers
Do you have a charged battery in there? :)
Relay needs power to work, or your blinkers won't blink but stay off.
The battery is brand new so I didn’t think that I needed to charge it. But your right it probably does need to be charged because since my initial post I have ridden it some more and now the blinkers are working at higher revs… I am going to give it a good charge when I find some time.
Also… are the blinkers supposed to stay ON? I initially thought that was a problem but maybe that how they are supposed to be…. Head light on with all the blinkers and they are blinking at higher revs…
Thanks for the replies.
The fronts I believe should stay on solid at all times, they're running lights.
The rears should be off, unless blinking to indicate turning.
I'm going to say that it's the signal relay (Blinker module). They are notorious to fail. You can pick up a generic automotive one at Can. Tire for 4-5 buck.
